| 6C - Fuel System Solex, Weber conversions, Fuel Injection, Fuel Pumps, etc. |
Unanswered: help
Opeler Forever, Ben |
If I understand what you are trying to say it sounds like vapor lock, keep your fuel lines as far from heat as you can, or insulate them.
#3 (permalink) | |
UngerDog
Jerry |
and it spirting out in short little may I say spuirts
vapor lock..the fuel boiling before the fuel pump fuel foaming is where the gas boils in the bowl of the carb. Judging from your location there's a beep load of the corn fuel (alky) in the fuel. Like the others have said keep the fuel cool. Or increase the fuel pressure which brings on its own problemes Last edited by wrench459; 06-10-2008 at 10:45 PM. |
the fuel line is not hot any where
the car runs great for 15 min then the fuel filter next to the carb does not have any fuel in it but you take off the fuel line and there is pressure, the fuel comes running out and the fuel filter fill's up i have a in line pressure gauge, it stays at 3 pounds. runing 32/36 weber
I'm betting on your fuel tank sock, if you still have one, is plugging the fuel line from the tank.
Real Name: Neil
Yes did you remove the fuel sock inside the tank? and since it sounds like you are getting fuel pressure all the way up to the filter on the fuel line just before the carburetor.... are you sure you have the filter hooked up in the correct direction?
Another possible cause is lack of fuel tank venting, try running the car with the gas cap off, and see if it still stalls out after 15 min., just a thought but I sort of doubt this would be the problem.
Mike's Opel Shop
Vacuum Leak
I had this problem a long time ago, I added a clear Glass type fuel filter right next to the carb. I found out that if your carb. or the the intake were leaking and had a "vacuum leak" or carb float level off, The fuel filter would not fill up.
I know I had fuel psi at the carb. I think it's a Vacuum leak,I sprayed the manifold and carb with carb spray and listen for RPM changes. Found Carb. mounting gasket leaking. Just my .02 cents.
MIKE --------------------------------------------------- 1972 Opel GT,Citris Yellow 2.0L, Weber 38DGES 1969 Opel GT in Paint Shop 1973 MGB, Red, Weber 38DGES I have pride in my rides
UngerDog
The first thing you should do is check that filter. It sounds to me that it is clogging. Take it off, shake it, then empty it into a clear container and examine it. You obviously have fuel pressure with the "hissing" flow of gas when you disconnect the fuel line before the filter. However, pressure doesn't mean that you have fuel flow. Also, when you relieve the pressure that way some of the clogging in the filter is released and a temporary correction occurs until you hook the lines back up and put pressure and fuel back in the line. A clogged filter is most likely a result of contaminated gas. And, contaminated gas can clog even a new filter quickly. So, check the condition of the gas, check for flow, and if those are good, put a new filter on it. Did you try any of the suggestions in the previous posts?
Jerry |
no fuel sock, good clean gas,fuel line is cool
took out filter and did the same thing,took line off and let it run into other tank good flow for over a hour fuel line comes out of the tank to a fuel filter, then the pump, then steel line to were the old fuel pump was then rubber to a new steel line that runs to a pressure gauge then to a filter just before carb where does the fuel presssure go after the carb ? does the pressure bleed off in the float bowl ?
Ben, most, if not all low pressure fuel pumps, electric or manual, are bypass flow pumps. That is, they bypass the fuel internally, so that when there is no flow requirement they just don't pump the fuel, but maintain the pressure. The carb float needle regulates the fuel flow. As the level in the bowl drops, so does the float and opens the needle valve to allow fuel flow. The needle can be overpressurized and cause fuel to flow when the bowl is still full, so that's the reasoning behind the 3 psi max pressure from the pumps. HTH.
That only leaves on thing to figure out. Why is the fuel not getting to the pump? The pump is working but not getting fuel, so it's pumping air when it doesn't get fuel.
