| 6C - Fuel System Solex, Weber conversions, Fuel Injection, Fuel Pumps, etc. |
Unanswered: Intake Manifolds
Any help appreciated. |
drill, tap, plug
Are you talking about one of the screwed-in fittings or the solid tube on the outside of the mainfold?
With the screwed-in fittings, unscrew them and get a brass pipe plug. The threads don't have to be a perfect match, it just has to start in the threads and tighten down. Between the soft aluminum and the soft brass the threads will malign enough to ensure you get a good seal if you tighten it enough. After all, do you really want the plug to come back out later? If you're worried about the press-fit steel tube, or you don't think the plug will seal in one of the other holes, buy the next size larger brass plug and the tap to match. Drill the hole out with the size called for on the tap, tap the new larger hole, and screw in the plug. Obviously you'll want the manifold off so nothing gets into the motor.
I'm talking about the screwed in fitting. I put a cast iron pipe plug in there but it didn't go in very far before it got tight and it looks pretty obvious. I wanted something that looked less "hey I removed my egr valve" for when I go to get this thing smog tested every year. The one in "Rally Bobs" pictures looked like it was pressed in or at least fit down inside the opening. Maybe it would be easier to work with the brass plug to make it look better. Thanks for the tip.
Site Admin
#10 (permalink) | |
If ANYONE has an old air pump from either engine (1.1 or 1.9) and used only on the early engines, '68 and '69 I believe, send me an e-mail. If from the 1.9 engine and you also have the mounting bracket, that would be a PLUS! Thanks.
Driver
Real Name: George
I used a pipe thread plug. Got it at O'Rielly. I don't remember the size but it was standard.
#12 (permalink) | |
#15 (permalink) | |
