Old 07-25-2004   #1 (permalink)
Dmcbrass's Avatar
Dmcbrass
Unanswered: Heat shield doesn't fit
I just changed the Exhaust/intake manifold on my GT. I was surprised to find that the heat shield didn't fit the replacement intake manifold. It seems that there are at least two different configurations of intake manifolds. The replacement one has a shorter rise at the carbureter connection. The bent ends of the heat shield are hitting the manifold leaving it 1/4" above the gasketed surface. Anyone else run into this? Are there different heat shields for different manifolds or did some Opels come without heat shields?
Dmcbrass is offline
Old 07-26-2004   #2 (permalink)
Arrow Heat shields
None came without heat shields. Parts manual lists two P/Ns for the heat shield:
P/N 850990 - '68-'72 Kadett and '69-'73 GT
P/N 850991 - '71-'74 All Model 50 (Manta/1900)
Can't tell you what the difference is though.
Old 07-26-2004   #3 (permalink)
Dmcbrass's Avatar
Dmcbrass
Based on my experience this weekend, I'm guessing that my new manifold is from a 71-74 Manta and that the difference is in the height of the heat shield.
Dmcbrass is offline
Old 07-26-2004   #4 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
phenolic gasket
Don't forget that the Solex also had a 1/4" thick phenolic spacer under it, which might have been under the heat shield, I can't remember. Even if it wasn't origionally, no reason one or 2 of the spacers couldn't go under the heat shield now to make up the difference. Much better idea, I think, than modifying the heat shield.
oldopelguy is offline
Old 07-26-2004   #5 (permalink)
Dmcbrass's Avatar
Dmcbrass
Oldopelguy,
That's a good idea. Where could I find a phenolic spacer?
Dmcbrass is offline
Old 07-26-2004   #6 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
how handy are you?
Well, that depends on how handy you are and what kind of tools you have. If you have a drill, saw, and at least a round file, I'd go with this:
http://cgi.ebay.com/ws/eBayISAPI.dll...829031212&rd=1
And make your own spacer(s). This retailer has been great with me in the past, and this material should do the trick nicely and leave you with plenty for spares or just in case.
If you're not so handy you could try to source a couple of stock Opel spacers, but they will need to be opened up anyway (to match the larger bore of the Weber) to work well, so the work is about the same.
Old 07-26-2004   #7 (permalink)
Dmcbrass's Avatar
Dmcbrass
Thanks for the info!
Dmcbrass is offline
