, 2", 2¼" & 2½", what should I use on a stock 2.0 N, that I can also use on a 2.2 E with a double barrel solex carb [thinking out loud in the future here: or two single barrel carbs, maybe even two double barrel carbs ].I'm thinking of making a complete SS exhaust system for the Ascona, but I need [read want] to know: how, why, why not, what to use and what not, ect, ect, ect. I've also read about 4" x 9" oval 11" mufflers what do they look like inside, and the same with the last round muffler? Als reading somewhere making a oval 4"x9" by cutting a 4" pipe in half and welding two pieces of 5" to make the 9" complete. How to connect the pieces shove them together or make flanges??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 11-30-2006 at 04:05 PM. Reason: Adding text |
erick whats your metal work skills base ?
working with SS is not easy , it does not bend as easy as mild steel it needs different gasses to use when welding it and filler wire if using mig or tig welding , the muffler needs to be made to cut noise without cutting flow do you want to make an absorbant muffler or a reflective one ? to make push and clamp fit you will need 2 sizes of pipe or an expander for the 1 size pipe (mucho euros ) to make flange ones you will need some 6 mm SS plate and a big drill bit i used to make my own when i worked for a company called powerbend but only because i had access to cnc benders , pipe plats a full MC shop and a workmate who used to work making custom exhausts so knew what to do inside a muffler much easyer to get a one from a manufacturer there are loads around , i even found one that lists the GT and manta A in the UK Double 'S' Exhausts - The Original and Finest Stainless Steel Exhausts Manufacturer in the South West of England, UK. We have been manufacturing quality stainless steel exhaust systems for over 25 years for performance and classic cars.
Buy your stainless steel exhaust from Welcome To MagnaFlow Performance Exhaust. They have everything you need and more...
Here is their direct link to universal mufflers: MagnaFlow Performance Exhaust - Universal Mufflers Dieter
a slip of the key and yes you're a "Cunning Linguist"
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 12-01-2006 at 03:47 PM. |
#6 (permalink) | ||||||
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 12-02-2006 at 02:47 PM. |
#7 (permalink) | |||
A reflective type muffler has a series of directional baffles that direct the exhaust sound frequency back at itself to cancel it out, in general it has been found that opels don't like that on account of decreased back pressure to the point that it is hurting performance.
1970 Opel GT 1.9 1980 Moto Guzzi V50 2000 Saab 9-3 2.0 turbo 2000 KTM 200 exc STOLEN Last edited by jordan; 12-01-2006 at 05:34 PM. |
aaaaaaaaaarrrrrrrgggghhh i just spent 10 min typing out an answer to this and lost it when it would not post
![]() ![]() ![]() gary can we have the old slow server that worked back please oh and what jordan says try Howstuffworks "How Mufflers Work" for a vid on how they work
Copyright © 2003-2009 barry williams All Rights Reserved save praying to God for sunday today we pray to Nike and run like hell Last edited by baz; 12-01-2006 at 06:09 PM. |
#9 (permalink) | |
I thought it was my PC making faults
#10 (permalink) | |
Nicely asked for it at the beer bottle filling plant today [ ], as if some one knew I needed SS pipe, so I toke a few meters home with me. They had two sizes:#1: 50.8 mm [2.00"]OD, 48.2 mm [1.90"] ID #2: 60.4 mm [2.38"]OD, 56.4 mm [2.22"] ID Would size #1 work for the first part and size #2 for the part over the back axle?? I was thinking about making a flange on the piece where the two pipes from the manifold come together [the Y section] and go with SS from there
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 12-01-2006 at 06:34 PM. |
#11 (permalink) | |
#12 (permalink) | |
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 12-02-2006 at 01:29 PM. Reason: couldend - could not? |
If you want whisper quiet then Magnaflow is NOT the way to go. Über loud at times. The only way to get one that quiet is to find some stock muffler off of a grandma car. If you pick a large enough pipe it probily won't hurt performance much. Also using 14 AWG pipe will lower the sound a bit. Don't install a header they make lots of noise especially in the cabin.
Arguing online is the same as racing in the Special Olympics; no matter who wins, you're both still retarded. Last edited by tekenaar; 12-02-2006 at 01:26 PM. |
#14 (permalink) | |
"toke" is a 'reefer/MJ' cigarette . . . from the late '60s . . . even a song written about it . . . One Toke Over the Line - Brewer and Shipley (Lyrics and Chords)
Here's what I've used in the past depending on level of engine performance: 2" for stock or small performance upgrade - 1.9/2.0 stock or carb/street cam/ sprint/exhaust; 2.25" for high performance street - 1.9-2.4 cam/valves/SSD/DSD/FI/sprint/header/exhaust.
Remember, the idea is to keep exhaust velocity UP!! to maintain as much torque as possible in the mid-range RPMs . . . the single most important aspect for "street engines". None of us are in the 5500+RPM range often enough to justify anything else, methinks!
Well lets see what I've got:
sprint exhaust manifold, stock double pipe between manifold and 1st muffler, need to make: #1 SS pipe [50.8 mm] from Y of double pipe to 1st muffler, 1 flange made of SS and 1 made of steel, 4"x9" oval x 11" muffler [or something similar], pipe from 1st muffler over the back axle to 2nd muffler [#2 pipe 60.4 mm], 4" round muffler [or something similar], end piece from 2nd muffler to the back of the car. The front muffler wil be some thing like picture 1, [but with the out going pipe in the center] and the back like picture 2
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 12-02-2006 at 06:22 PM. Reason: Adding text and photo's |
#20 (permalink) | |
Don't think they make any "absorbing" oval mufflers with in and out pipes in the center, only baffled/reflecting types. I like using the centered pipe as the entry on the JCW mufflers I use and use the edge pipe as exhaust and oriented toward the outside of the car. This allows me to lean the "over axle" pipe toward the center of the car for extra clearance of the tilted GT shocks. Should give the same results with the other models.
#21 (permalink) | |
#22 (permalink) | ||
Can I use the following size tubes?? #1: 50.8 mm [2.00"]OD, 48.2 mm [1.90"] ID, front pipe #2: 60.4 mm [2.38"]OD, 56.4 mm [2.22"] ID, pipe over the rear axle
#23 (permalink) |
2" exhaust pipe
You can certainly use those and maintain good exhaust velocity for both engines mentioned. Personally, I would use 2" pipe for the "over-axle" pipe as well, as there will be no discernible performance difference in the sub-5500RPM "street" range you'll be using . . . my opinion, anyway.
#24 (permalink) | |
Granted, this was on a Manta, so the axle pipe has to take a 90 degree turn up, then 180 degrees over the axle, then another 90 degrees into the rear resonator (360 degrees worth of turns in 18"!). Even though the diameter is larger the velocity gets killed climbing over the rear axle and making those turns, so the larger pipe keeps up the exhaust gas speeds. This was with two mufflers, a small 2" inlet/outlet oval body before the axle, and a 5" diameter round body (2" inlet/outlet) behind the rear axle. I also tested the exact same combo with a pair of 2.5" mufflers (same 2" primary tube however), and in that instance I felt I lost low end power but gained mid-top end power. It was also 4 db louder, although the same brand and externally dimensioned mufflers were used. The bigger diameter obviously has different accoustic values. Bob |
#25 (permalink) |
@ Rally Bob:
If I understand you correctly: use the 50.8 mm [2.00"]OD, 48.2 mm [1.90"] ID pipe,for the front pipe and going in the 1st muffler and use the 60.4 mm [2.38"]OD, 56.4 mm [2.22"] ID pipe for over the rear axle. And for the 1st muffler the 50.8 mm in and 60.4 out with a size of 4" x 9" oval x 11" length, and the second muffler Ø 5", 60.4 in and out. And about the rear axle try to make the bend as shallow as possible. Is this some what close to what you were saying???
