Old 12-10-2006   #1 (permalink)
Wolf Spyder's Avatar
Wolf Spyder is on a distinguished road
Unanswered: Manifold removal (remove thermo housing)?
The shop manual I have says that the intake and exhaust manifolds are removed together by unbolting it and lifting it out as one unit. Well the bolts on the collector were very rusted and as I am planning to put on a pacesetter header I cut the two pipes as high as I could with a cutting wheel (that's all I have) Problem is that when attempting to lift them out the hang on the thermostat inlet. Question is, is the inlet O.K. to remove so I can remove the manifolds?
TIA
Henri
LIFE IS NOT A JOURNEY TO The GRAVE WITH THE INTENTION OF ARRIVING SAFELY IN A PRETTY AND WELL-PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING...
"WOW! WHAT A RIDE!"
Wolf Spyder is offline
Old 12-10-2006   #2 (permalink)
jordan's Avatar
Perfectly fine to remove the thermostat housing, There is a gasket that will most likely need replacing, you could try putting some RTV sealer on it, but I don't suggest it. Remember you will loose some coolant when you take it off so have a pan ready on the floor.
1970 Opel GT 1.9
1980 Moto Guzzi V50
2000 Saab 9-3 2.0 turbo
2000 KTM 200 exc STOLEN
jordan is offline
Old 12-10-2006   #3 (permalink)
69whitegt is on a distinguished road
Ah c'mon now, RTV seals EVERYTHING!!! But don't take my word for it.
____________________________
. 1972 GT "Carl"
. 2.0
. Maxcomp cam
. Sprint Manifold
. Factory Automatic
. Solex Carb (don't hate)
69whitegt is offline
Old 12-10-2006   #4 (permalink)
Yeah! Everything .....
Water passages, oil galleries, fuel lines etc. etc. - Too much of it does!
