Unanswered: Restrictive Exhaust Collectors!!!
Anyone had any experience with an aftermarket collector or building their own? Seems I could get some power back by opening that up considerably or is there something I am missing (that is....other than my marbles) Gary Sullivan
NYAsconaGuy |
#2 (permalink) | |
UFO pel abductee.
L jetronic and is the limiting factor to any engine mods. A higher capacity air flow meter may have been found that works on the '75 intake manifold and maybe someone can tell you about it.
restrictive exhaust
That subject has been flogged back and forth for a number of years. If the car is going to be used as a street driven vehicle, then an exhaust header ran with a muffler is of little benifit below 5000-5500 RPM and they come with a lot of baggage (rust out, warped flanges, blown out gaskets and so forth). My prefered system is a 75 FI (Sprint) manifold with a modified headpipe that requires an exhaust shop with a tubing bender to make. (1) increase the size of the down tubes to 1 3/4" into a y'ed collector with 2" outlet and 2" tubing back to a low restriction muffler (2" inlet/2" outlet) then y'ed again behind the muffler and 2" over-the-axle pipes back to the "dimples" if it is too loud for your taste, use two packed tips to cut down on some of the noise. This is not a cheap system because it requires time, material and labor to build but done right it will be there a long time and perform much better than a "stock" system (IMHO)
Restrictive exhaust
The system I told you about is for a GT, in the case of a Ascona/Manta you do noth need to have the Y behind the muffler, just run the single over-the-axle pipe and use the packed tip if it is too loud for your taste.
Missing Something ...
As you move away from stock specs in camming, valve size and carburation some extra power can be unleashed by opening up the exhaust system behind the exhaust manifold.
Stock
Thanks for the replies. Very helpful.
I haven't tinkered with the internals. I have stock fuel injection, stock heads, etc. (relatively low mileage car) I am now doing the math on the amount of the restriction at the center of the Y (on the head pipe) and it still blows me away. The reduction in mass at the Y is astonishing. But it sounds like I want to be careful how much tinkering I do if I still want around town drivability. This car is a driver. Never raced. Only used around town. I have some take offs head pipes I can experiment with and was considering trying a 2" flowmaster collector at the Y end of the head pipe. That would open up that connection hugely and should allow it to breathe better. Anyone think that is likely to make the car less smooth running and docile for daily driving? Gary
NYAsconaGuy |
Gary;
I have a 75 Sportwagon, pretty much stock, except for Pertronix ignition. Although I converted it from auto to 5-spd, the exhaust was modified. It's stock till it gets to the front muffler, it's a MIDAS Gold off the shelf, then over the axle, eliminating the rear muffler/resonator and using a straight pipe out, with a MONZA dual tip. Sounds great, not like a ricer, but, does have a good "tuned" sound.
"Yes, I do have a rifle rack in my Sportwagon" Last edited by tekenaar; 12-24-2007 at 04:44 PM. Reason: had to look 'in' on elimating . . . ;-) |
