Old 04-06-2006   #1 (permalink)
Wolf Spyder's Avatar
Wolf Spyder is on a distinguished road
Unanswered: Pacesetter header and intake missmatch
I got this header from a member for my GT and the flanges are not matching up to the intake that I am going to use. In the attached photo you can see where the problem is. The questions are, 1) which should I grind to make the fit, header or intake? 2) It appears that when I do grind one or the other to make them match up that the throat of the intake will be resting on the right exhaust pipe. Maybe even to the point of not allowing the bolt locations to match up. Do I bend the pipe? 3) Is this contact going to affect the intake by heating it up too much? 4) what are possible solutions.
Thanks in advance.
Henri
LIFE IS NOT A JOURNEY TO The GRAVE WITH THE INTENTION OF ARRIVING SAFELY IN A PRETTY AND WELL-PRESERVED BODY, BUT RATHER TO SKID IN BROADSIDE, THOROUGHLY USED UP, TOTALLY WORN OUT, AND LOUDLY PROCLAIMING...
"WOW! WHAT A RIDE!"
Wolf Spyder is offline
Old 04-06-2006   #2 (permalink)
henri to save some posting problems with photos ,you do not need to post to your album and then link to a thread
all you have to do is have the photo in a jpeg of 640 x400 and use the manage attachments button below the note box you type in
in there you can browes for the pic in your own files and add it then we get the small thumbnail which expands when you click on it
the way you are doing it gives a small thumbnail only and saves having a double post of a picture
hope this helps
Old 04-06-2006   #3 (permalink)
PaceSetter!
From previous posts these headers are known for the problems you have, most are bashed and ground to fit - you must have a new set!
You may find that the rear pipe contacts the engine mount too ......
Nothing for it but to grind away the exhaust header flange and ding the pipes - that way any other intake should fit if you change intakes.
Old 04-06-2006   #4 (permalink)
just come back with the photo ready to edit and find that its been otto'd
thank you sir
Old 04-06-2006   #5 (permalink)
I would grind the header flange. You may also have clearance problems with the #1 exhaust pipe and the intake. I've been able to get clearance by grinding the intake. I've also beat the header with a ball pein hammer for clearance and stress relief.
hrcollinsjr is online now
