Ben, if you're running the stock jets that came in the weber then there is no doubt you are running rich at our altitude. The weber is jetted for sea level so you will have to lean out the mixture by changing your jets. If you look on line I believe there is a web site that tells you the jetting. I know Liz has a cheat sheet as well.
new braided ground strap
retimed re adj carb new jets i put 130's in the float bowl left the rest past emissions at idle hcc standard 700 reading 220 co standard 5.00 read 1.44 co2% 13.6 at 856 rpm s high speed test hcc standard 700 reading 394 co% standard 5.00 reading 10.44 co2%7.6 at 2389 rpm help still runing rich right ?
Opeler Forever, Ben Last edited by ben; 08-08-2007 at 10:45 PM. |
with a co reading of 5.00
If i remember this right try to hit the 3.0 range for the CO reading I believe thats 12:1 air fuel ratio best for power!! yep your rich as beep
Tinkering is my name..fun is the game Last edited by wrench459; 08-08-2007 at 10:44 PM. |
Hire me Now!
High carbon monoxide (CO) emissions are a telltale sign of a rich fuel mixture. On older carbureted vehicles, fuel-saturated plastic floats, incorrect float settings, leaky power valves and misadjusted chokes are often responsible for the rich mixture. On newer vehicles with feedback fuel controls and fuel injection, leaky injectors, excessive fuel pressure and sluggish or contaminated O2 sensors are all possibilities to investigate.
...I pulled the above off the following website.. Emissions Testing: Exhaust Analysis More possibly pertinent information further down on that page regarding failed CO emissions at acceleration. They note a flooded charcoal canister could be the problem in addition to much of the same as what's above. How does one hook up the Charcoal Canister to a Weber anywho? Does all of Utah require emissions testing? What's the rules? I always thought in most places there was an age limit on cars that didn't require testing. You're little Opel is too new?
your HC is good no misfire none at all don't worry about this part Now I'm sure the air induction is long gone I.E smog pump Put a three way CAT on and your done you can always remove the CAT after the emisions testing
Tinkering is my name..fun is the game Last edited by wrench459; 08-08-2007 at 11:15 PM. |
The 135 Main jet on the Primary side is the Otto perfered size for a stock 1.9. However, you will need to check your idle jet as it is controls idle and part throttle...
Paul |
#14 (permalink) | |
Opelitis since 1984
Real Name: Charles Goin
But 135-140 on the gas 160-170 on the air works well. Most start with 135/160 primary 140/165 secondary My Sons Manta runs a 32/36DGAV (18B Double Pump) Motor is a 2.0L Pistons - Stock Valves - 75 Manifold w/ 2" exhast and a 74' Manta Street/Hot Ported Intake)(2.0L Pistons, Stock Valves, 75 Manifold w/ 2" exhast and a 74' Manta Street/Hot Ported Intake. Its Jetting came too 140a/160f Primary, 140a/160f Secondary My Kadett runs a standard 32/36DGEV, the motor is a 1.9L Stock High Compression pistons & valves, 75 Manifold w/ 2" exhaust and a 74' Manta Street/Hot Ported Intake. Its Jetting came too 135a/160f Primary, 140a/160f Secondary. A GT I just built is running has 140f/160a Primary, 180f/175a Secondary. The Secondary was based solely on the GT was running lean during hard accelleration so I wanted to bump the jets. and these were the largest I had. I had a ton of 120-140 fuel & 135-165 air jets and these two jets, So I stuck them in to see how they would run.... it seemed to work great. The Motor is a rebuilt 1.9L w/ 2.0L Pistons & Valves, Isky Hot Street Cam, 75 Manifold w/ 2" exhaust and a 74' Manta Hot/Street ported intake. I am pretty sure the idle jets are 50 for all three carbs.. Although I think the Manta has 55 jets on both sides.
CURRENT '06 Pontiac GTO '71 Opel Kadett 4 Door 36D (w/ Opel Parts & Service 2.0L) '74 Opel Manta (Bens Manta) '74 Opel Manta (w/ LK5 transplant) Past '73 Opel Manta (Blue Max) '75 Opel Manta (Yellow) '85 Bitter SC '73 Opel Commodore B GS '73 Opel GT (w/ Vinyl Roof) At least 16 or So Parts Opels Last edited by GoinManta; 08-09-2007 at 10:05 AM. |
#15 (permalink) | |
Oh, and Charles, your GT is running "pig-rich" in the secondary . . . basic jetting rule-of-thumb for everything but "full-race" is not to allow main fuel jet to exceed air corrector jet size, i.e. fuel/air ratio less than 1:1. So, just replace your secondary main fuel jet with a 155/160 and it'll run even better . . . trust me!
Opels like 4.5 - 5.2% CO for maximum power. They like fuel.
But for street use, better off with 3 - 3.5% under load. Idle can be as low as you want it to be (1 - 1.5%), as long as it doesn't have a lean-misfire condition, since that would increase HC emissions. |
