Unanswered: Bolt size-Pressure Plate to Flywheel
Dave |
#2 (permalink) | |
long time Opeler
Check out the FSM Download link on the right hand side under downloads. It's the clutch pressure plate that has the wrong torque values in the FSM. Run a search for clutch or pressure plate and you should find your answer. Hth, Jarrell
flywheel bolts
Only problem with using the factory service manual is the torque specs. for these bolts is misprinted and you will streach and weaken them if you torque them to that spec. The proper torque is 18 foot pounds and you want to make sure you have at least a grade 10-12 bolt with the proper shoulder. Thread Locker is added insurance but is not as important as using the proper bolt.
My cable modem died last night at home as I was typing a response, that seems to have been answered in reference to the FSM (which I have) with wrong torque specs.
I still need to know what size bolt to buy that is rated 10/9. Any help with that? Dave |
Parts Book ....
Torque for them is listed as 15 to 18 lbs-ft.
