The clutch has been getting progressively harder and harder to push in. The clutch was engaging the final 2 or 3 inches when the pedal was pressed to the floor. It took a good amount of pressure to push it. I assume this pressure broke the shaft. Before it broke, I tried to fix it, I checked the clutch cable from the firewall which was at its fullest extension. I replaced the tension spring under the car with a lighter gage (the other one looked a little big) and it seemed to help a little for a couple weeks. I also had a lot of trouble loosening the 8mm nut on the bell housing. I made sure I used an 8mm box wrench vs. a socked per the words of a member who posted to an issue someone else had. But I couldn’t adjust the arm. I realize the issue is deeper than the pivot bolt; however I need to get one to address the underlying problem. All the parts cars available to me are automatic – Can anyone point me to a pivot bolt? Does anyone have advice on this matter? Thanks in advance! |
Hard Clutch
A hard clutch could develop from a number of causes:
Clutch cable improperly adjusted at firewall Clutch cable improperly adjusted at bellhousing Clutch cable stretched internally Clutch arm in bellhousing is bending Clutch release bearing wearing out Clutch disc or pressure plate wearing out Another factor is stress on the pivot bolt. If the car is a 1968-1971 GT, this could be alleviated, with installation of the pedal pivot bolt bracket to the firewall (as installed originally in 1972-1973 GT's). Last edited by Anonymous D; 06-12-2007 at 03:25 PM. |
Just the shaft
Hey Gary - I just need the shaft ( i think). Everything else appears to be ok. I will know if other components of the assembly were damaged when I try to get the replacement shaft. Thanks!
Site Admin
Found everything but the GT pedal assembly. Got one for an automatic, one from an Ascona, but could not get to the right box where I think it is....
Did manage to find 4 pair of GT door handles that I was looking for last March. Several distributor caps that I needed. A good 012 distributor and a SSD manifold that I had completely forgotten about. |
PrOpeller
I think Skip's problem lies in the throwout bearing or clutch. The clutch fork was incredibly hard to move back and forth from underneath. And if he was able to break the pedal by applying so much force, there's also a chance that the cable will be stretched, too.
Skip, are you going to be able to make German Car Day? |
#9 (permalink) | |
Thanks Gary
I'm glad you made it back in one piece Gary! Are you able to use the parts you just found that you needed last March? Hey, you could put together a tag sale/BBQ and kill a few birds with one stone!
Thanks for risking life and limb to find the part. I appreciate the help. I really wanted to get the car going for next week. Maybe I can steel away for a minute and run up to Bugaboo Creek to bug tonight. Thanks again Gary! |
