Old 08-17-2008   #1 (permalink)
AZManta's Avatar
Real Name: Tom Esterkin
Unanswered: clutch disc to flywheel clearance
I have a 2.4 engine with a 5-speed Getrag, and had a noise because the springs in the clutch disc were rubbing the inner area of the flywheel.
On inspection of the new parts, I find that the new parts will likely have the same problem once the lining on the disc wears. Any suggestions?
Tom
AZManta is offline
Old 08-17-2008   #2 (permalink)
Welsh Wizard's Avatar
Welsh Wizard is on a distinguished road
Noise from Clutch
Are you sure the release bearing is not the source of the noise? and while your in there always change the 'spigot' bearing ( little needle roller bearing in the flywheel)
Any pictures?
Welsh Wizard
Welsh Wizard is offline
Old 08-17-2008   #3 (permalink)
Is this the OEM Opel Clutch, and if so, I presume it is the 2.4 clutch? I don't know that clutch, but if it is like the 1.9, then the friction disc has to be "right side up", or else the springs interfere with the pressure plate when released. Have a read at:
http://www.opelgt.com/forums/7a-clut...weel-side.html
