Where does this spring belong?
Results 1 to 17 of 17
Like Tree3Likes
  • 2 Post By opelspyder
  • 1 Post By Knorm65
Thread: Where does this spring belong?
    Member Red0ktober's Avatar
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    This came off my Kadett, but I don't know where. Is it a clutch pedal return spring perhaps?
    1971 Opel Kadett Wagon - TBI EFI with MS2, Prepping for LeMons Rally - Summer 2017
    1972 Opel GT - parts car
    1998 Volvo V90 with Ford 5.0 V8 Swap
    2003 Land Rover Discovery SE7
    2016 Honda CRF1000L Africa Twin
    Hoosier Opeler Site Supporter My location rrossjr's Avatar
    Mar 2004
    indiana
    1,512
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    Cool. I kind of assumed based on the size and context of parts I found it with, but I took it apart three years ago and my memory is rubbish.
    Apr 2003
    Portland, Oregon
    6,537
    Quote Originally Posted by Red0ktober View Post
    Although it isn't necessarily needed to operate the car, the purpose is to hold pressure on the clutch arm to keep the arm from resting the throwout bearing on the clutch fingers. It also helps reduce chatter while not touching the clutch pedal and it helps to keep the clutch cable from disengaged the ball/socket connection at the end of the clutch arm.
    There's a hole that it goes into on the transmission cross member.
    A lot of little things from just a simple spring.
  7. #5
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    I'm not seeing where this spring goes. The transmission support crossmember seems too far away, and I don't see any holes in it.
  8. #6
    Apr 2003
    Portland, Oregon
    6,537
    Keep in mind that anything I say about stuff like this is based on the similarity between the GT and the Kadett and 1.9 drivetrain.
    So, on the tranny crossmember. On the Driver side, on the lower part of the flange, is usually a hole. It's less than 1/8 inch and is often covered in road gunk so it's hard to see if the spring was missing.
  9. #7
    Tennessee
    4,135
    Keith Lundholm
    I'm going to go on a limb here and say that is actually an emergency brake lever return spring. On a Kadett the clutch return spring is shorter and goes into a hole of the externally mounted reverse switch.
    hrcollinsjr and Knorm65 like this.
    www.newvintageauto.com
  10. #8
    Apr 2003
    Portland, Oregon
    6,537
    You might be right. I won't argue.
    There was nothing hooked to that hole on my sons GT (his was the one in the picture) and even though I drilled a hole in the crossmember for my T5, I didn't hook the spring there. I hooked it to a spot on the transmission. I can look later at my unmolested pumpkin tonight.
  11. #9
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    I never disassembled anything related to the parking brake, but I'll take a look.
  12. #10
    Apr 2003
    Portland, Oregon
    6,537
    Are you sure you aren't playing with your throttle return spring?
  13. #11
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    No, that spring is accounted for.
  14. #12
    Can Opeler Knorm65's Avatar
    May 2014
    Wichita Falls and Munday, Texas.
    1,739
    Kyler Norman
    4
    It is the parking brake return spring I just saw it when I rebuilt my rear end.
    Red0ktober likes this.
    "Mira," 1970 Opel GT ARA AC, European 2.0L and Weber DGAS
    "Kara," 1972 Opel GT Targa "Fancy Rat Rod"
  15. #13
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    Ok, that's where I put it. I don't remember taking it off. I only recently rebuilt my torque tube, but the spring had been taken off long before that.
    I have no return spring on my clutch arm, nor do I see anywhere to anchor one on the body or crossmember. Perhaps I will make something.
  16. #14
    May 2014
    1,739
    Kyler Norman
    4
    The early 69-70Gts have a little hole in the reverse light switch attached to the driver side of the tranny that it attaches to.
    I forgot where it is on the 71-73, but It's somewhere on crossmember or tranny I think a few inches off from the center of the car to the driver side.
  17. #15
    Oct 2002
    Mahopac, NY
    4,034
    1973 is in the tranny support. You can see the hole but I am not using it due to the 5 speed.
    www.markandson.net
    www.gpny.com
    '64 VW Ghia '09 S35 BMW Z4
  18. #16
    Dec 2011
    Hood River, OR
    287
    Paul Gerstenberger
    Is this a GT or Kadett?
  19. #17
    Oct 2002
    Mahopac, NY
    4,034
    Sorry, this is a 1973 GT.
    www.markandson.net
    www.gpny.com
    1. T.O.O Spring getogether
      By jlthunder in forum Northeast
      Last Post: 05-05-2011, 03:59 PM
    2. T.O.O Spring get together
      Last Post: 03-31-2011, 10:50 AM
    3. Spring Thing
      By krewzer in forum Texas Opel Club
      Last Post: 06-08-2008, 09:23 PM
    4. Driveshaft spring
      By ConreroGT in forum 4B - Propeller Shaft and Central Joint
      Last Post: 02-01-2005, 02:50 AM
