Old 05-01-2007   #1 (permalink)
101st Airborne Vet V.N.
MICAH1's Avatar
Real Name: Thomas Johnson
MICAH1
Unanswered: 69 Transmission
Having my clutch replaced tomorrow morning, and will have the four speed manual transmission checked during the process. If I run into a suprise with the transmission I have a spare 1969 back-up. Question, can the 1969 transmissions be swapped to a 1973 GT?? Did not see anything in the search engine on this topic.
Thomas
MICAH1 is online now
Old 05-01-2007   #2 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
I do believe that the only difference's might be the speedo cable hook-ups.I do know the early vs. later cables are of different lengths and the actual outputs on the tranny are different. I am not sure about the back-up light switch either, someone else may be able to chime in on that issue......
Joe
yellaopelgt is offline
Old 05-01-2007   #3 (permalink)
69 vs. 73 Manual Transmission
You would need to check, whether you need to extend the wires to the backup light switch, as well as whether your speedometer cable will reach the end of the "L-shaped" gear "extension" piece.
Check the condition of the seals in the 69 before installing it. Replacement seals are sold for the speedometer gear (2), shifter shaft (2) and rear output (1). You can swap over an existing front cup seal, or replace it with a new one.
Always replace the gasket to the bellhousing when reinstalling a transmission, and use gasket sealer (to avoid leaking gear oil from the trans). If the used trans has worn gears, filling with "straight" 140W gear oil (not multi-viscosity) will quiet them.
Anonymous D is offline
Old 05-01-2007   #4 (permalink)
MICAH1's Avatar
MICAH1
Unhappy
Just talked to Gil at OGTS who said the problem with the swap would be the speedometer would read way off. I'll keep my fingers crossed that the trans is ok. Guess I will bring the part up to Carlise, to sell or give away...
Thomas
Old 05-01-2007   #5 (permalink)
Speedo can be changed
Simply replacing the dash speedo with a W=897 gradient speedo, would keep the MPH readout gearing accurate.
Old 05-01-2007   #6 (permalink)
No Access
The 69 uses the same speedo cable but on the opposite side and uses a 90 degree drive for it. The 69 and 70 had an external reverse switch where later years were internal. All the speedo driven gears at the tranny side are interchangable although some are pinned in place and some have a bolt in piece. Swap the driven gear from old to new and you will be fine. The older wires for reverse are a bit longer but wire up the same. HTH
nobody is offline
Old 05-02-2007   #7 (permalink)
soybean's Avatar
Thomas, if you go with that 69 swap, I have 3 dash speedos with a W=897 on the face should you need them. The 90 degree drive, I don't have as I was looking for one for Karl earlier this year. Jarrell
soybean is offline
