Curve Crazy GT
Unanswered: Bye Bye tranny...
I dont understand i didnt drop the clutch or anything, just casually went to back up and this happened... the trans never leaked before this. and i know it was full of fluid cause ALOT poured out. any explanations?
thanks chris Owned Cars: 1973 Opel GT 1980 Chevy Monte Carlo-Current 383 project drag car. 1972 Chevy Monte Carlo 2005 Dodge Ram 1500 |
take a good look at the cracked case when you dissassemble it to see if any of the crack has rusted. I suspect it has been cracked for some time and just now came apart. perhaps a defect in the casting.
TMK |
Happened to my friend at the racetrack once, literally dropped gears out onto the ground! But he was not very patient and was a little abusive on the tranny in reverse... Bob |
Dieter
Mid-West Opeler
Are you UP and running with the new trans. Tell us all, how did you drop the trans.?????
Manta Ray
This happened to my Manta's auto trans - I was driving along fine and came to a stop, but she wouldnt shift out of first after that. Noticed that the trans fluid was strangley low and refilled, then started driving and had transmission fluid shooting something like seven feet out from under the left side of the car. Once we finally got it up on jacks, we found that a hole 4" wide was cleanly made on the side of the housing - works fine with a new casing...still have no idea what could have caused that...
Curve Crazy GT
It didnt seem like it was cracked before there is no rust on it. Like others have said i think the reverse gear just poped out and it went down hill from there.
As for taking it out,i put the front way up on jack stands,i could not get the top two bellhousing to motor bolts loose, so i just undid the 4 bolts that hold the trans onto the bell housing and pulled it out (sawdust helped me with that idea because he was here picking up some windows at the time.thanks!), and slipped my new (to me) back in place. Im waiting on a trans mount that is on its way right now , so i havent got a chance to put it all back together yet.
Chris, IIRC, I got the two top bolts out from the top, reaching behind the engine with a box end wrench. But then I'm kinda petite in stature and have been know to get in to places most folks can't. I believe when I was putting the bellhousing back in, I used a 24" extension with a universal.
I like how you break stuff. You don't mess around. All the explanations offered work for me, but my favorite is always "$#it Happens".
#14 (permalink) | |
The Method ...
2) Don't forget a new gasket between the g/box and bellhousing ...
Goodbye Transmission
I always used rubber body plugs (same as in the floor) and they worked well. I had them in the Transmission tunnel to get to the two top transmission bolts in my Drag car. I broke so many transmissions I would go to a three day event with one in the car and three spares (and hope I had enough to last all weekend) my son and I had the change down to a science, I think our best time on changing one was 12 minutes with hand tools.
Curve Crazy GT
So i just went to go put the trans back in place and relized my 4 bolts to the bell housing have been knocked over... they all are diffrent lengths and i do not know where each one goes...
does anybody know where each of the bolts for the gear-box to bell housing go?? they are 4 diffrent lengths!!!
The long ones go to the top holes and the short ones go to the lower holes. The two lower tranny mounting holes are partial blocked, the bolts have to be short... So do a trial fit to see which bolts will go in the lower tranny holes first, this check the corresponding holes in the bell housing to make sure the threads match... Then you should be good to go
Paul |
Curve Crazy GT
Thanks! that helped and it all back to gether now, runs good and smooth no vibrations or leaks!
![]() thanks to all! now... anyone want anything off of that old trans? linkage, reverse light switch? anything...
#20 (permalink) |
Kalifornia Kid
A bit late to this post, but......
Yup, been there, done that...... Almost can't count how many 4 speeds I've killed. Killed two of them exactly like that!, back in the late 80's! Would have paid anything for a 5 speed Getrag back then!!
#21 (permalink) |
Curve Crazy GT
I would ahve loved to put in a 5 speed seeing as i drive it to school and back some times, 140 miles each way. But with my other project going i just dont have the money for it at this point. Because as of right now im trying my best not to have to sell the GT for my current project.
