Unanswered: Sloppy Transmission
I'd either check to see if all 4 bolts holding the trans to the bellhouse in your current car are tight first. If they are, then swap the other trans in.
Just like Gene has said, check the trans. fluid also .
HTH John
And check the pilot bearing when you pull the transmission out. Other reasons are worn internal bearings, bent main shaft etc. which all are reasons to replace the transmission.
The most common cause is loose bolts between the tranny and bell-housing, and the next symptom is a piled-up tranny, as the oil leaks out between the tranny and bell-housing. Ask me how I know...
Wobbly Lever?
Is it the shifter that is 'sloppy' - or the gears inside the trans?
Fix It!!
So the shifter is worn and sloppy .... and you are still using it when it obviously is malfunctioning - for goodness sake FIX IT!
Continuing to use it will just ensure that the gearbox suffers .... and dies Take the bus or pushbike till it is repaired - Please
#8 (permalink) | |
sloppy transmission
#9 (permalink) | |
'72 Opel GT (Sara)
Matt
well i aint really driving. (that long of distances) ill drive it around the neighborhood but she gets roudy after the engine starts to warm up. but what actually causes the shifter to have so much slop? i mean im surprised it still works.
No....its not a Buick....
In almost every circumstance I have ever seen with "sloppy" or tough to shift lever it was done because of 2 reasons. 1. bad/worn clutch plate or cable and unknowing driver has forced the gear shifter into place. 2. linkage has been bent up so bad from being forced into gear that it now has a mind of its own.
Could be bad synchros as well (dont think you could downshift if that were the case)but bottom line usually comes down to operator error.Have you tried to adjust the clutch and/or cable and see if it will shift easier?? That seems to be the normal on these Opels......adjusted mine a while back and now its effortlessly smooth!!! food for thought... Joe
