Old 02-24-2008   #1 (permalink)
1971 GT
CDN OpelNut's Avatar
CDN OpelNut
Unanswered: Tranny Wiring Help
Does it make a difference which spade the purple wire and the black/white wire connect to on the tranny? Just connecting my Getrag and there's no indication of what goes where. Maybe it doesn't matter as its just completing a circuit?
CDN OpelNut is offline
Old 02-24-2008   #2 (permalink)
opelwasp's Avatar
Doesn't matter, but if I'm wrong switch them, there's only two options.
opelwasp is offline
Old 02-24-2008   #3 (permalink)
heimue's Avatar
If you put 'em on wrong, it changes your internal switch mechanism, and you will have 5 reverse gears and only one forward gear.
Sorry I couldn't resist. Yes of course, since it is "only" a switch, it absolutely does not matter. Technically speaking, if a switch gets actuated, it means that two or more poles (here: two) get connected, so that an electrical current can flow between the poles. Electrical current doesn't care whether its flowing from A to B or from B to A. You can easily understand that example: if an electrical wire has 120V on it, it doesn't matter on which end you touch it, you get whacked in any way.
Dieter
heimue is offline
