Unanswered: manual trans girdle
And I'm not very easy on transmissions in the first place. After doing a search and coming up empty. Has anyone tried a girdle for the case? Or maybe a better idea to make the pan a structural part of the case. Yes this is till I get a 5 speed. |
#2 (permalink) | |
One, more fluid takes longer to heat up, and Opel trannys get REAL hot under hard use. I know in road racing the biggest cause of Opel 4-speed failure is heat, not breakage from shock-loads. And two, I also made the pan from some pretty heavy material...the flange is 3/16" thick and I believe the rest of the pan is 16 gauge steel. So it's way stiffer than the stock sheetmetal pan, and should let the case flex less than stock. I figured it couldn't hurt. I thought about a wrap-around weld-on reinforcement, but the time spent would probably be ridiculous, and the case would probably warp anyway. Bob
Thanks Bob
That TURD thread needs to have a sticky on it "must read" Lots of cool info in there. Back to the pan cooling fins or some extra plumbing to an external cooler? Most people complain about the noise from the stock trans..straight cut gears I'm game. How much and what kind of power will it take? Never mind the dollar is not that strong..but the Quaife parts looks good Last edited by wrench459; 03-01-2008 at 11:10 PM. Reason: Quaife |
#4 (permalink) | |||
