This has been going on ever since I had to replace my broken 2.0 with a 1.6, does any body have a clue what is causing this
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by tekenaar; 05-12-2009 at 09:57 AM. Reason: hole - gat; whole - heel |
Most Helpful Answer - Posted by 2 Fast 4 U
This is what I found: http://i24.photobucket.com/albums/c4...Automaat11.jpg http://i24.photobucket.com/albums/c4...Automaat12.jpg the 3 pieces, the big one was lying in the pan and the two other pieces were in the filter http://i24.photobucket.com/albums/c4...Automaat13.jpg http://i24.photobucket.com/albums/c4...Automaat14.jpg |
I don't know, Gene, but can this happen just by pulling the auto trans and putting it back in again?
Uber Genius
If I were you, I would start by removing the transmission pan and replacing the filter then refilling with new tranny fluid.
Than I'll have to find a oil filter for the auto trans
If you can't find one there in the Netherlands, give me a shout, I have two kits sitting on the shelf.
UFO pel abductee.
Have you checked the hot fluid level on the dipstick? On some automatic transmissions it doesn't have to be very low for what your describing to happen with cold fluid since the fluid expands quite a bit as it heats up.
-Mark '75 Manta Direct link to my album of Opel related parts catalogs and magazine articles for reference: http://www.opelgt.com/photopost/show...ser/23031/sl/a Last edited by tekenaar; 05-12-2009 at 09:51 AM. Reason: Have you check? |
#9 (permalink) | |
About the fluid level, I check that very often because the trans has a leak in the front and in the back seal, so that isn't the fault.
I could remove the pan and put in a filter from one of three other auto trans I have, just to get rid of the problem for now until I have a new filter. Is there a way to flush the trans to see if there is more gunk in it??
Opel Ascona; driving one is like living on the edge. Only built from 1970 - 1975 Last edited by 2 Fast 4 U; 05-12-2009 at 03:03 PM. Reason: added question |
Just because so many people seem to forget how to check auto trans levels: You do check the level in the transmission with the car running and in either neutral or park, right? Because if you were checking it with the car off the level would not be correct due to an uncertain amount of fluid draining back into the pan from the torque converter.
Sounds like you need to just install one of your other transmissions if you are losing fluid out both ends. That or pull yours out and replace seals and such.
I check the level in the trans with the engine running at operating temp [± 90°C] and in the N position.
Transmssion Troubleshooting
"Slow gear engagement
Description: If the transmission is placed into gear when the engine is warm, it takes a while to engage into a gear. Occasionally you can speed up the engagement by pressing on the gas pedal, but it may occur with a clunking noise. Possible reasons: The transmission fluid level is low or incorrect There is an internal problem in the transmission The idle speed of the engine is wrong The transmission filter is clogged The throttle linkage is out of adjustment or damaged" |
It's not slow gear engagement, but slow coming to speed and it doesn't happen when the trans is warm, only when it's cold and for about 50 meters/yards of driving, then the trans works normal until it hasn't been used for a number of hours
UFO pel abductee.
If after you service the filter and still have the problem, I've had great luck
with balky auto trans control systems by adding a bottle of Lucus TransFix after removing a similar amount of the atf. I most recently put it in a '63 Ford Cruisomatic to stop a front pump seal leak and it not only pretty much stopped the leak but the trans now shifts much better. If it's headed for a trans shop anyway, it might save you a trip. I really don't like additives for the most part except as a last resort to maybe avoid a large repair bill.
This is starting to sound like a Torque Converter Stator
that is damaged ( Roller Clutch ) . This would require Trans. removal ....I would O.H. Trans. at this point because metal from Torque Conv. goes into the Trans. pump. HTH John
#17 (permalink) | |
![]() Provided Answers: 10
The main cause is some of the front seals in the body are hardened and they take a bit of time to expand and come back to life. If you change the fluid and replace the filter, you might make the situation worst if this is the first fluid change after lots of miles. Simple way to see if it is a seal problem is to put the car in "L" when you start out from a cold condition. If the gear engages rapidly or after a few seconds without any additional RPMs, then a tranny reseal would be in order. I believe you should have either a TH180 or a TH200 which are simple to work on and not that expensive to reseal. As an example, a TH200 could cost you about $600 to reseal.
The pump for the trans is behind that front seal. The seal is old and hard and was probably deformed when you switched motors if you left the torque convertor hanging on the input shaft for any length of time. Now the pump is sucking air as it tries to prime itself after sitting for a bit. There is an air bleed valve that may be sticking also, but it is most likely the seal-pump combination. You can always try some of the seal softening additives and see if it helps.
#19 (permalink) | |
UFO pel abductee.
That's why I suggested the Lucas or other brand that coagulates the leak at the seal rather then softening the seal which would at best be pretty sort lived.
#20 (permalink) |
Where can I find the air bleed valve?
@ blancojp: It's a TH 180 trans
#21 (permalink) |
There is no air bleed valve in this trans. , there is a pump priming check valve in the pump body . If this was damaged ( I have never seen this happen ) the converter would be slow to refill at first engagement of the trans. ( car would not move at all ) when the converter filled , car would work as a normal shifting trans. with no loss of pull also when you stopped car and turned eng. off converter would drain back into the trans. case and when fluid was first checked it would show overfull by app. 3.0 qt.HTH
John
#22 (permalink) |
I called it an air bleed valve since that is what I always called it I guess. I haven't worked on one of these since everything went electronic.
Guyopel is correct though, It is in the pump body and I have never seen one fail either. If it stuck closed it would prime slow and if it stuck open the transmission would never work properly at all. But I have seen lots of front seals leak and I still think the loss of prime is the problem. I've been wrong plenty of times and will be wrong again. Since you have problems anyway I don't think an oil & filter change would do any harm. As far as seal softeners working as Aardvark asked: No, I've never seen the problem go away for very long. |
#23 (permalink) |
I don't believe in those things anyway, the only way to solve those problems, is to change them for new ones
#24 (permalink) | |
I found a repair shop, near my work today, and ordered a filter and pan gasket for € 38.92 incl tax, going to pick it up tomorrow ![]() I asked the lady on the phone if I had to come by and order in person and do a payment, "no" she said, "I'll call you tomorrow when I have the filter and gasket in front of me", thats something new to me here, normally one has to order in person and do a payment even before a shop orders anything. So if every thing goes well, I'll be installing a new filter on Saturday [after doing the weekly shopping ] I asked this before is there a way to clean/flush the trans after I take the old filter out and before I put the new one in??
#25 (permalink) | |
Uber Genius
Some people have been known to replace the trans filter and pan, fill it, then run it a few miles and then change the fluid again, reusing the new filter and pan gasket. Not much you can do beyond that if the trans is in the car.
