Old 03-04-2006   #1 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Question Unanswered: Tranny and rear end oil type?
What is the preferred brand and weight of manual 4 speed tranny and rear end oil used in the GT? Just drained both in mine after sitting for 10 years (at least).
Bo
Bo Mows is offline
Old 03-04-2006   #2 (permalink)
spdkilz02's Avatar
spdkilz02
i used regular 80 weight gear oil...
Adam
spdkilz02 is offline
Old 03-04-2006   #3 (permalink)
asdasc's Avatar
Just out of curiosity, how did you drain the diff? Did you just pull the cover and let it fly? I was looking at mine today and didn't see a drain plug. I must admit, I didn't look REAL hard, but I was thinking about doing what you are.
Steve
asdasc is offline
Old 03-04-2006   #4 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Yep, just dropped the cover and cleaned it out and cleaned the cover and put it back on. I didn't even look for a plug. When the cover came off, it just kinda oozed out.
The tranny oil was really new looking. I think the PO did it when he rebuilt the motor.
80 weight in both?
Bo
Bo Mows is offline
Old 03-04-2006   #5 (permalink)
spdkilz02's Avatar
spdkilz02
yeah its just regular gear oil...
Adam
Old 03-04-2006   #6 (permalink)
duaneb's Avatar
duaneb
gear oil
FSM for my 73 GT list 80 or 90 wt in both
duaneb is offline
Old 03-04-2006   #7 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Lucas Gear Oil?
Any comments on Lucas Gear Oil? I really like the Lucas motor oil in my 190,000 + Dodge Ram 318. Never used the gear oil though.
Bo
Bo Mows is offline
Old 03-04-2006   #8 (permalink)
One of the bottom bolts in the diff. cover will is supposed to drain the gear oil.
I put heavy weight gear oil in my tranny years ago. It worked fine until the outside temps started dropping. I got tired of having to force it into gear until it got to a decent operating temperature.
Old 03-04-2006   #9 (permalink)
opelnut10's Avatar
Gear Lube
80W is fine, I also get a quart of MOROSO high performance lube and put half in the transmission and half in the rear end. It may not help but it don't hurt a thing, it can stand high temps. better than regular gear lube. If you take the top and bottom bolt outta the rear cover after running it up on jack stands it will drain out and not make a big mess. Nothing smells as bad to me as used gear lube and if you get it on you it has to wear off. After you let it drain take the cover off and clean it and fill with lube till you can stick your pinky in the fill hole and bend it at the first joint and touch the lube, just right then. Transmission has a magnet in the bottom of it's pan check it and clean the debre off and fill with the same method as the rear end.
opelnut10 is offline
Old 03-04-2006   #10 (permalink)
opelwasp's Avatar
I always use syntheticgear oil. Royal Purple, Red Line, Castrol Syntec, Mobil, all make synthetics. I run it in my engine after break in, trannys auto and stick, and diffs.
opelwasp is offline
Old 03-04-2006   #11 (permalink)
Bo Know's '69's
Bo Mows's Avatar
I wondered about using Mobil 1. I have 2 commercial mowers (hense the name Bo Mows) and both use Mobil 1. As gear oil in my 36" walk behind and hydro oil in the 52" Zero turn mower. Will it effect anything if i used it in the tranny and rear without contamination from the previous lube in the GT?
Bo
Bo Mows is offline
Old 03-05-2006   #12 (permalink)
layed521's Avatar
layed521 is on a distinguished road
I have been sold on Lucas gear oils & oil additives. I see & hear the difference everytime I put it in 1 of the vehicles that comes into my shop. I have Lucas 80/90 in my diff & trans.
'71 Datsun 521
'71 Opel GT
layed521 is offline
Old 03-05-2006   #13 (permalink)
bo mobil 1 will not be good as it will not work right as a gear oil
you need a hypoid gear oil
old axles ,old technology ,old type oil
fully synthetic oil will kill the seals quick time and put your axle in the junk heep when it brakes down and dont lubricate the gears
Old 03-05-2006   #14 (permalink)
soybean's Avatar
I have to agree with layed521, I use Lucas gear oils & oil additives in almost all my farm machinery, with the exception of my John Derres' transmission. Since it is a synchro shift, it requires a special oil.
Jarrell
soybean is offline
Old 03-05-2006   #15 (permalink)
2 Fast 4 U's Avatar
To drain the oil of the dif you have to remove the bottom bolt of the cover and leave it open for a while
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 03-05-2006   #16 (permalink)
Can't really go wrong with Amsoil or Redline synthetics. Less friction and better bearing protection is good. If you decide on synthetics, make sure you get gear oil specifically for a manual transmission...the rear axle gear oil is too slippery and will make it tough for the synchros to engage. Redline sells something called 'MTL' (manual transmission lube) which I swear by for Opels.
If you swap out the tranny lube, rear axle lube, front wheel bearing grease and engine oil for synthetics, expect 1-1.5 mpg better mileage and a few mph better top speed. It even makes the car easier to push...
Old 03-05-2006   #17 (permalink)
2 Fast 4 U's Avatar
Do you have a car to push?? and that's why you put in that special oil??
Opel Ascona;
Old 03-16-2006   #18 (permalink)
Matt M240Z is on a distinguished road
How much oil does the 4-speed transmission take on the GT? Also, how do you fill it up? I am changing the transmission fluid for the first time by myself.
"The past is past, the future is now"
Matt M240Z is offline
Old 03-16-2006   #19 (permalink)
kent's Avatar
what size are the trany pan bolts ? I lost and need all new
kent is offline
Old 03-16-2006   #20 (permalink)
The FSM lists capacity as 2.5 pints, using either 80 weight or 80W-90 weight gear oil.
There are ten (10) bolts holding the oil pan to the transmission case. The thread pitch is 6 mm x 1.00. I don't have any bolts on-hand, but the depth of thread engagement into the transmission case is only about 10 mm. Add the gasket thickness and oil pan thickness to this number, and that's the max length bolt you can use. So probably no more than 12 mm long.
Old 03-17-2006   #21 (permalink)
Do you take the oil pan off and fill it up with 2.5 pints and bolt it back on to fill the transmission? I just need to know if that is all that is required before I go to get oil and get the car up in the air. Thanks
Old 03-17-2006   #22 (permalink)
its been a long time since i played with one of these boxes but i think theres a drain plug in the base plate and theres a filler plug on the side that has a square head (dont quote me on this ) and you fill the box back up till the oil just runs back out of this hole then refit the plug
Old 03-17-2006   #23 (permalink)
Ok, just got back from Napa with a quart of SAE 75W-90 gear oil. On the back, it says "recommended for all hypoid differentials (conventional and limited slip) and manual transmissions where an API GL-5 or MT-1 fluid is specified". This should work right? And is 2.5 pints really all the transmission needs? Thanks again
Old 03-17-2006   #24 (permalink)
asdasc's Avatar
If I remember right, you refill the trans thru the shift boot. Pull the center console, push the shift boot over to the side, reach your hand in the hole and there is a twist off cover. I use some 3/8 inch fuel hose on the end of the oil tip and fill it. Does it just fill to the top? That sounds vaguely familier.
Steve
asdasc is offline
Old 03-17-2006   #25 (permalink)
Just crawled under the car and the only plug that I saw was a hex head bolt on the driver side of the transmission about 3 inches above the oil pan. I assume this is the fill plug? If there is a drain plug, where is it, or do you have to take the oil pan off?
