Unanswered: 32/36 Weber
#2 (permalink) | |
Site Admin
You can also click on the "forums" link at any time and navigate to the Forum you posted in. HTH, Gary |
Depends on the carb
Whether one carb or another is better for a rebuild, depends on the condition of the carb itself.
Check for looseness at the main throttle shaft bushing. This is where the linkage attaches to the carburetor (on an Opel, this is on the side of the carb that is more towards the rear of the car). If you can "wiggle" the throttle shaft within the carb, that means it is worn. If wear is excessive, that can cause an internal vacuum leak on the carb. Assuming other aspects of the carb are roughly equal (meaning, there isn't excessive rust on the water choke, or other wear on the other carb pieces), then the carb with the tightest throttle shaft bushing may be your best rebuild candidate. Generally, the series 33B-1 carbs are the more recent carbs (the series 5A are the older ones), and if you drive in Southern California you are better off in that climate using an electric choke (water choke works best in cold temperature driving, at 45 degrees F or below). Installing the electric choke also means you can eliminate 2 water hoses (which improves your heater function). On most Weber 32/26 carbs, you can swap over the water choke for the electric (and vice-versa) if needed. Once a carb is rebuilt, installation and tuning tips can be found here: Engine |
Also, I'd check the jet sizes before I just bolt the carb up to see if it will run. What may be a perfectly good carb, might be jetted completely wrong. After testing you may think something is wrong with the carb when really it was just the jets.......
Paul |
if you go the electric choke way and remove the 2 "tee's" that feed the choke
remember to store them some place safe , they are getting hard to find
. . . oh, and electrical connection for e-choke is black/yellow wire at right horn (switched 12V)!
#9 (permalink) | |
Black/yellow Wire Connection On Right Horn!
. . . that's how the Opel factory originally did it for the '73 GT's Solex e-choke, what could be simpler! . . . uh, didn't see your avatar, but solution's the same . . . the switched 12V connection on the horn, NOT the brown, ground, horn-button wire !
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 06-15-2007 at 10:53 AM. Reason: other-than-GT solution |
Mr corey suggs
I'd go with the water choke.
IT MY WORLD, COREYS WORLD Official EX-PREDIENT of the MWTE! © Mr. Corey Suggs Last edited by tekenaar; 06-15-2007 at 02:29 PM. Reason: Id - part of ego, AFAIK |
