Old 06-26-2007   #1 (permalink)
Opel Rekord Coupe
kips's Avatar
kips is on a distinguished road
Unanswered: Weber Carburettor
Hi,
I'm currently running a Solex carb (32 DIDTA), on a 1.9 block. I'm looking for parts for that carb or a direct weber replacement.
either
WEBER 32/36 CARBURETTOR
or
WEBER 38 DGAS CARBURETTOR
Does anyone have a weber that would just bolt on?
Thanks
Kips
kips is offline
Old 06-26-2007   #2 (permalink)
TonyB
TonyB is on a distinguished road
Opel GT Source
Hello,
Opel GT Source sells weber carbs for Opels (direct replacement) but I am sure you can find the exact carb they use in europe. Try to do a search of the forum to find the model number you need.
Tony
TonyB is offline
Old 06-26-2007   #3 (permalink)
if the engine is stock look for a vauxhall with a 32/36 dgv so the ports are the right way round or theres a 32/32 dgas type weber that works
the 38/38 dgas is a bit much for the stock motor and will need jetting down to run right
the ford 32/36 dgf has the ports the wrong way round so the mix is bad for the CIH engine
where are you btw
Old 06-26-2007   #4 (permalink)
The 32/36 and 38 are both bolt ons, but, if you're running a basically stock 1.9, then go with the 32/36, as it is more "forgiving" than the 38. The 38 WILL HAVE TO BE TUNED to your motor, but, the 32/36 does not have to be. It can be improved by tuning it for your motor and type of driving, but, will run right out of the box. Also, the 32/36 has 3 different chokes: manual (DGS), water (DGAS), and electric (DGES). Get the electric, it's a one wire hookup.
Old 06-26-2007   #5 (permalink)
Lindsay
Weber Re-jetting
Excellent discussion regarding 32/36 Weber:
http://www.opelgt.com/forums/afterma...ferrerid=14028
Lindsay is offline
