Old 07-24-2007   #1 (permalink)
Thumbs up Unanswered: Rekord C "Sprint" specs from Opel
Most of you have shared my frustrations trying to find an original Rekord C "Sprint" air cleaner for my dual DFO intake over the past few years . . . still haven't even found any alternatives I could use! Although it doesn't help me specifically with this problem, I was given some related help from two sources.
Uwe, a mutual German friend with some of you here, found a source for and was kind enough to send me a copy of the original factory assembly manual for the three "Sprint" models offered - 2-Door Sedan, 4-Door Sedan and Coupé. It details all the differences between the standard and "Sprint" models, entirely in German, of course.
Production of the Rekord-C "Sprint" models began in January 1968 with Chassis-number 4 146 951 and using a modified 1.9 CIH engine as basis. The two most significant changes were the first use of lighter pistons, later used in all production CIH engines, and a 19H cylinder head with 48.8cc combustion chambers to produce a rated CR of 9.5:1.
The manual devotes an entire section to the "Sprint" intake with 20 pages of set-up and adjustment procedures . . . everything you could possibly want to know about the Weber 40DFO!
The most interesting tid-bits for me were the two photos of each side of a completed "Sprint" engine which showed the use of two different length intake manifold braces to "prevent vibration cracking". I wondered what those lowest paired, threaded holes on the manifold were for! Now I know . . .
About a week later and before losing another bid for a "Sprint" air cleaner on German e-Bay, way too much money for me, I ran across a Repair Manual for Opel Rekord C (1966-1971), including Rekord Sprint, Commodore A and Commodore A/GS . . . just had to have it!
Old 07-24-2007   #2 (permalink)
Thumbs up Saga continues - Reparatur anleitung Opel Rekord C (1966-1971)
. . . and now the second part of my little "Sprint" saga.
I received this manual by Deutsche Luftpost a little while ago and promptly perused it, cover to cover. Though everything's in black-and-white, the manual is filled with photos and diagrams in much the same way my earlier Rekord PII factory manual is. It has the absolute best "blow-up" carb diagrams in it and two items which I had not been able to find information on in 30+ years.
The most interesting to everyone here is a dimensional flywheel drawing with the factory spec for the clutchface "step" . . . Opel flywheel clutch faces are stepped, not flat like most American cars, but the step dimension is not found in any factory manual . . . that I'm aware of anyway!
So, here it is: Flywheel step - 4.5mm +0.1mm (0.177" +0.004")
The second thing is something I've wondered about for a long time, but of interest probably only to some fellow Solex users . . . ever wonder what the two threaded and connected holes in the carb-base boss next to the idle mixture screw are for?
I've seen pictures with two nipples screwed in, but never really could think of any reason for them. Thanks to this book I now know . . . the two nipples are plumbed into the coolant system, in the same way that the water choke is, and is used to heat the carb primary right at the idle and transition ports! Probably originally designed for Norway, Sweden and Finland use . . . gets really cold up there, you know!
So there you have it . . . my two-book saga is now complete!
Old 07-24-2007   #3 (permalink)
Originally Posted by tekenaar View Post
. The most interesting to everyone here is a dimensional flywheel drawing with the factory spec for the clutchface "step" . . . Opel flywheel clutch faces are stepped, not flat like most American cars, but the step dimension is not found in any factory manual . . . that I'm aware of anyway!
Actually this is posted in some of the service manuals...can't remember if it's the Chiltons or Haynes, but I've seen it in print before.
Old 07-24-2007   #4 (permalink)
Otto, I have all these manuals in English, encompassing the standard Rekords as well as the 'Sprint' supplemental manual. Definitely some interesting reading. Different camshaft and valve springs, 1.9H head, the newer designed pistons, the intake and twin DFO's, the 'Sprint' manifold, the 'Sprint' valve cover (same as GT, but came out before the GT), etc. Good reading for the tech junkies! I have made copies of the inlet manifold tuning procedures for other Opel owners in the past.
Old 07-25-2007   #5 (permalink)
2 Fast 4 U's Avatar
Possible to scan??
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 07-25-2007   #6 (permalink)
I don't own a scanner, maybe Otto does though.
Old 07-25-2007   #7 (permalink)
Arrow Alternative . . .
Originally Posted by 2 Fast 4 U View Post
Possible to scan??
How about this instead! . . . or this!
Old 07-26-2007   #8 (permalink)
2 Fast 4 U's Avatar
Possible to scan??
would like only the part with the 1.9 engine & carb with intake manifold, don't have any use for the complete book, just forget I asked
Opel Ascona;
Old 07-26-2007   #9 (permalink)
Thumbs up Print this PDF file!
Twisted my arm . . . just print this PDF file then!
Old 07-27-2007   #10 (permalink)
2 Fast 4 U's Avatar
thank you very much!
Twisted my arm, humbug
Opel Ascona;
Old 03-27-2008   #11 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
alpharm is on a distinguished road
I am looking for a manifold for this 19H engine.
Does anyone know where i can find any new or used?
Thanks
alpharm is offline
Old 03-27-2008   #12 (permalink)
opelspyder's Avatar
Which one
Which manifold do you need the intake or the exhaust??? The intakes come up on German ebay quite regular, and the exhaust is same as the 1975 Us Sprint manifold from my understanding
Keith
opelspyder is offline
Old 03-27-2008   #13 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
Ok sorry!!!
I am looking for the intake manifold for a friend of mine
Do you have any e-bay links since i do not use often
Thank you a lot!!!!
alpharm is offline
Old 03-27-2008   #14 (permalink)
OpelGT-de is on a distinguished road
..sometimes it is cheaper to buy a complete car
I contact
this
OPEL Rekord C 1.9 srint coupè su eBay.it Opel, Auto, Auto
seller.
Hi asking price is 1000 Euros for a complete Sprint Coupe with all the very rare goodies.
(btw the car with the demaged RH front fender is not the Sprint Coupe, it is a very ,very ,very rare 69 "Sprint " 4-door Sedan ,also available for less money)
...hhhmmmm..... or......
OpelGT-de is offline
Old 03-27-2008   #15 (permalink)
www.opelgtworld.de
opelgtworld's Avatar
opelgtworld
Opel GT with 40DFOs
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)"
opelgtworld is offline
Old 03-28-2008   #16 (permalink)
OPEL PARTS GREECE
alpharm's Avatar
What to do the whole car since only the intake manifold wanted?
Also nice work you have done there to your GT
alpharm is offline
Old 11-20-2008   #17 (permalink)
blind_msq's Avatar
blind_msq is on a distinguished road
Thumbs up
Hello everyone!
I found this forum while googlein' for opel rekord c documentation and this topic came up. Unlike most of the members that usually register to a forum and ask for something, i'd like to break the tradition and help the owners of Opel Rekord C ('66-'72) with the factory manual.
You may find the first page in the attachment. The manual has somewhere around 1100 pages; rekord owners (and not only them) that are interested in the manual may send me a private message and we'll find out a way for them to have a copy of it. I know how hard it is to find good documentation, that's the main reason why i registered this forum.
The main disadvantage is that the book is in german (at least for those who don't speak german...i'm one of those) but it's better then not having anything to get inspired.
I also have some documentation about various types of carburettors (and about some other car models); if someone in need, ask.
PS: Excuse me for further (and actual) bad english expression, i'm not a natural born english speaker and i don't usually speak/type in english, altough i read daily websites in eng.
File Type: jpg opel rekord c factory manual first page.jpg (78.4 KB, 23 views)
blind_msq is offline
Old 03-30-2009   #18 (permalink)
Nevmenoz is on a distinguished road
How could i get this nice manual???
Nevmenoz is offline
Old 03-30-2009   #19 (permalink)
blind_msq's Avatar
Check your private messages.
PS: If you have any documentation feel free to tell me, i'm making a collection
If you see some young bastard driving a white nissan (and later a silver opel) avoid jaywalking...He's insane!
