Old 09-10-2007   #1 (permalink)
1970-GT
Unanswered: Weber 38DGAS Power valve
My GT has been running great above 2,500rpm, pulls strong, plugs look great!
But below that, it runs rich, loads up, stumbles.............
If I turn the A/C on, it's worse!!!!
My GT:
1970 GT, 2.0, 265 Chevy pistons, 9.5:1, RallyBob designed ported big valve head, with a F306/290-8 cam from Cam Techniques, roller rockers, RallyBob intake, MSD/pertronic ignition, modified distributor, NGK plugs .040 gap, quick trip header, 2" exhaust, K&N air filter.
My 38DGAS:
Note: altitude is 20ft
Main-150
Air-180
Idle-50
Pump jet-55
Emulsion Tubes-F66
Power valve-6-1/2 pop-off
The problem is my idle vacuum is about 8-9 at 1,100rpm when warmed up.
When cold less than that.
When I accelerate the vacuum drops below 6.5 and the power valve opens, messing up the mixture.
When the A/C is on, the rpm drops slightly and the vacuum drops below 6.5 and the power valve again opens!
If I just open up the throttle plates (1,200-1,300) to compensate, then the transfer holes start feeding fuel and it runs rich.
Solution:
Eliminate the power valve!
I took an old one I had, cut the rod and removed the spring!
The car now idles smoother and partial throttle is better.
It still pulls very strong above 2,500 and the plugs look great!
Any thoughts?
Should I try cutting the power valve spring to get the pop-off vacuum to 4-5, or just leave the power valve off?
Lyle
Tru-Craft is offline
Old 09-10-2007   #2 (permalink)
krewzer's Avatar
Real Name: Wes Thomas
BUMP.......................
I need to hear about this! My setup is similar, and I'm experiencing nearly identical vacuum and throttle response problems. Have a new power valve to replace existing one, but would love to hear about options.
krewzer is offline
Old 09-10-2007   #3 (permalink)
jvandyke's Avatar
Me too. Struggling with a 38. I don't know if my power valve is involved. Still learning. In my case, I get stumbling and hesitation on acceration (under load), plugs look okay to me (ain't saying much).
Supposedly has a hot cam so I don't have much vaccum at speed either. I have to learn about Powervalves I guess.
jvandyke is offline
Old 09-10-2007   #4 (permalink)
Site Admin
Gary's Avatar
Real Name: Gary
There are a couple of good posts on this topic:
http://www.opelgt.com/forums/6245-post26.html
http://www.opelgt.com/forums/91336-post122.html
http://www.opelgt.com/forums/117050-post15.html
Gary is offline
Old 09-11-2007   #5 (permalink)
1970-GT
Gary, thanks for the posts.
I was going to cut the power valve spring, but, because of the low vacuum signal I have with the A/C on, the power valve would be set really low (about 4-5).
I thought this would make the power valve almost useless.
Lyle
Old 09-12-2007   #6 (permalink)
krewzer's Avatar
As I was scrounging thru a few carb bodies for another power valve, I found three power valve spacers, on a valve assembly, in an early Italian Weber 38. Do these act like cutting the spring down in order to modify the power valve?
krewzer is offline
Old 09-12-2007   #7 (permalink)
1970-GT
If the power valve spring was a low compression rate, then yes, if a spacer was added you could adjust the vacuum by adding or removing spacers.
Mine has no spacers, so cutting the spring is the only way to adjust it.
I still don't have my power valve hooked up, and its running good.
I am going to leave it off until I do a dyno day.
Then try putting it back on set to 4-5.
Lyle
Old 09-12-2007   #8 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
I am wondering if the "stumble" with the weber 38 isnt just a coincidence. I have heard of a few opelers that have the same scenario. I was told the transition from idle jets to mains wasnt smooth and thats just they way it goes.It gets better with re-jetting but is still present no matter what you do. This seems to also happen with the 32/36 to a certain degree as well. So is there a possability that because the aftermarket weber carbs werent excactly set up for use in our opels? I could be WAAAY off here but, there are just too many people with the same issues.
just wondering............
Joe
yellaopelgt is offline
Old 09-12-2007   #9 (permalink)
Site Admin
Gary's Avatar
Real Name: Gary
Originally Posted by yellaopelgt View Post
I am wondering if the "stumble" with the weber 38 isnt just a coincodence. I have heard of a few opelers that have the same scenario. I was told the transition from idle jets to mains wasnt smooth and thats just they way it goes.It gets better with re-jetting but is still present no matter what you do.
F-66 emulsion tubes cured my "stumble".
Gary is offline
Old 09-12-2007   #10 (permalink)
1970-GT
jvandyke, like RallyBob said in the other thread, your fuel pressure/volume is too low and can't keep your float bowl full.
Fix the pump problem first.
My fuel level in the bowl is about 1/2 way up the 2 larger holes above the main jets.
Your jets should be in the (155 mains/180 air) range after you fix your fuel delivery problems.
Lyle
Old 09-30-2007   #11 (permalink)
krewzer's Avatar
Lyle,
What ever happened with your disabled power valve on dyno-day? Curious if you kept it out of operation.
Wes
krewzer is offline
Old 10-04-2007   #12 (permalink)
Tbags32
tbags32
Where is the power valve located and how do you cut the spring?????
Tom
tbags32 is offline
Old 10-04-2007   #13 (permalink)
1970-GT
Lyle,
Wes
Wes, still driving my Opel without the Power valve.
It's running good.
I hope to do a Dyno test day at the end of the month.
Following the other dyno day thread.
Lyle
Old 10-04-2007   #14 (permalink)
1970-GT
Tom
Tom, the power valve is located in the top half of the carb.
Between the float.
3 screws hold it in.
Cut spring with a small diagonal cutting pliers or a dremel with a cutoff wheel.
Lyle
Old 02-01-2008   #15 (permalink)
Weber Carburetor Guru
With the power valve there are several different ones. but what you are doing is nothing new.
on the DGV webers for Formula Ford Race cars, shops like Ivey Engines take out the power valve diaphram and use 2 brass tubes that pick up gas from the bottom of the float bowl and then they go thru the carb lid and then they exit just above the main venturis. This to get more gas at full throttle.
The 40 DFI and the 40 DFO do not have power valves. You do have to go a lot larger on main jets to make them run good.
bigjim5551212 is offline
Old 03-02-2008   #16 (permalink)
My GT:
My 38DGAS:
Main-150
Air-180
Idle-50
Pump jet-55
Emulsion Tubes-F66
Solution:
Any thoughts?
Lyle
I have not checked vacuum on cars for a long time. But this sounds really low. Like if you had a camshaft in it. I had a Datsun with a vacuum guage on it and it was about 15. When I took a tune up course once, it was said to tune your car to the highest steady vacuum. You might have other issues like ignition timing and such, but thats my 2 bits worth.
Old 03-28-2008   #17 (permalink)
1970-GT
Yep, the cam is the low vacuum "problem".
Can't have an agressive cam profile and idle good.
Still don't like the way my GT runs at idle/partial throttle.
But, it runs so good above 2,500rpm's!
Waiting for RallyBob to come to Florida next month!
Need some tuning help.
Lyle
Old 04-17-2008   #18 (permalink)
1970-GT
I ordered some jets to try and get my bog below 2,500 a little less.
My 38DGAS before:
Main-150
Air-180
Idle-50
Pump jet-55
Emulsion Tubes-F66
Power valve-blocked off
My 38DGAS now:
Main-152
Air-185
Idle-55
Pump jet-70
Emulsion Tubes-F66
Power valve-blocked off.
Talked to a Weber Tech guy (Joe) and he said Formula Fords (low vacuum engines) block the power valves, like bigjim5551212 said in a previous post. He never tried it on Opel's but thought it should work.
Joe suggested:
*Richen up the pump jet.
*Go richer on the idles and leaner on the mains.
He also said the idle jets control the fuel flow up to about 2,500rpm's and they still are dumping fuel in at higher RPM's. That's why he suggested richer idle's and leaner mains.
The bog is less, but still present.
Seems to be running better at higher rpm's, and pulls very strong above 3,500 to 7,500.
Oh, I put the power valve back on, and the bog was worse. Removed it.
Will try 057 Idle jets next.
Getting close.....amazing what a couple thousands of an inch larger hole can do!
Lyle
Old 04-18-2008   #19 (permalink)
jmbinjax's Avatar
jmbinjax is on a distinguished road
Keep Us Updated
Please keep us informed. I'm in the process of building an identical engine except for the roller rockers and the header, I'm using a sprint exhaust manifold.
jmbinjax is offline
Old 04-18-2008   #20 (permalink)
1970-GT
If your motor is close to mine this would be a good starting spot.
My 38DGAS now:
Main-152
Air-185
Idle-57
Pump jet-70
Emulsion Tubes-F66
The low end response is pretty good below 2,500 now.
Lets remember what we have here.
Only 2,000cc, 2 valve motor, not a cross flow head, aggressive cam, carb, older ignition system.........
Upper end power is very good!
We are so spoiled with modern motors, 40 years of technology is hard to beat! Fuel injected, 4 valve heads, variable port runners, electronic everything!
But, expensive and most of us can't work on them.
Let's not forget the advantages of our Opel's. I can rebuild my carb & ignition system and be running in 2 hours! For less than a $100 bucks!
I will take my GT.
Lyle
Old 04-21-2008   #21 (permalink)
1970-GT
I sprayed Ether around my throttle shafts and the idle changed a little. The Weber guy, Joe said this was normal and the shafts are not sealed,(.004-.005") is normal play.
The shafts ride in the white plastic split sleeves.
Being a machinist, I rebuilt my carb and added 4 Teflon spacers. They help locate and seal the throttle shafts.
In the attached picture, they replace the orange/brown bushings.
No more vacuum leaks!
I went to .60 idles and the bog is really reduced.
My mains were too lean, was not pulling as strong above 3,000rpm's, changed back to 150/180.
Very happy with the response now!
My 38DGAS now:
Mains- Fuel-150/Air-180
Idles-60
Pump jet-70
Emulsion Tubes-F66
Because of the very low altitude here (better air) I can run richer jets.
You folks in higher altitudes, maybe try:
Mains-150/185
Idles-55-57
Lyle
Old 04-28-2008   #22 (permalink)
1970-GT
PVC problems
PVC hose to intake manifold was messing up my carb mixture!
OK, the throttle plates open together on the Weber 38DGES.
I have a 5/32 (.156") ID hose coming from my valve cover to the intake manifold on the engine side.
Problem!
1)This is letting in air unevenly into the manifold!
2)The carb bore near the hole is leaner than the other bore!
3)Also #2 and #3 intake runners will be leaner also!
I decided to fix this.
*First I plugged the old manifold fitting.
*Then removed carb and pulled off the spacer.
*Then I modified the spacer.
I drilled a .157 hole into the side of the spacer, between the bores and press fit a barbed vacuum fitting.
Then I drilled a 3/32" hole in the center of the web that connects to the .157 hole. This will let air in evenly between the bores.
Re-assembled and started up with no other changes.
My Idle screws had to be re-adjusted!
The car now idles smoother!
Because more air is being drawn through the carb now, Idle vacuum is higher (8).
This might also help #2 & #3 cylinders from being leaner than 1 & 4.
Lyle
