Old 12-19-2007   #1 (permalink)
G54B-GT's Avatar
G54B-GT is on a distinguished road
Question Unanswered: Tuning the 38DGAS on stock 1.9L
PO had installed a 38 DGAS on an otherwise stock 1.9l 72 GT Automatic.
Read somewhere that this is too much carb for a stock motor.
Scanned the thread about the emulsion tubes and the power valve, but don't want to invest time into all that if this is just the wrong carb to begin with.
Anyone know if the 38DGAS can be effectively tuned on a stock motor????
G54B-GT is offline
Old 12-19-2007   #2 (permalink)
opelwasp's Avatar
It is a pain to tune for a stock motor, it is way too much for it. But it is a good excuse to get a motor that can handle it.
opelwasp is offline
Old 12-19-2007   #3 (permalink)
tomking's Avatar
Or I will trade you for a good Solex.
TMK
tomking is online now
Old 12-19-2007   #4 (permalink)
jvandyke's Avatar
That 38 is probably worth at least $200, I watched the market all summer and ended up getting one off ebay for $170 and considered that a good deal. I suggest seeing about trading it for a 32/36 and a bag of chips.
BTW
I lost the electric choke "gasket" plate (plastic disk that fits between choke element housing and carb body). What's a good source for a part like that?
jvandyke is offline
Old 12-19-2007   #5 (permalink)
It's not 'too much' carburetor, I've done a ton of 38 DGAS' on stock engines, even with automatics and low compression, dating back to 1984.
But it is significantly tougher to tune on a stock engine. The automatic amplifies any bad tuning, it has to be 'just right' or it will be a PITA to drive.
Old 12-19-2007   #6 (permalink)
G54B-GT's Avatar
Suggestions?
For a rookie opeler would you recommend a different carb?
This car ultimately will be driven by my mother who will not be comfortable in a tempermental car.
I was looking to switch to a 32/36 for driveability and reliablilty.
Thanks for your input.
G54B-GT is offline
Old 12-19-2007   #7 (permalink)
A 32/36 is simpler by far. Unless you have the box of jets, time, knowledge, and patience to rejet the 38 DGAS properly, then I'd suggest the 32/36 DGV instead. But I was just trying to clarify that the 38 DGAS is a viable option and can be made to work, even if it's not the correct choice for everyone.
Old 12-19-2007   #8 (permalink)
Mike's Opel Shop
opellane's Avatar
38 DGAS is a Great Carb.
I owned my GT now over 13 years, and had C & R Small Cars ( Bob) install a Weber 38 on a nearly stock motor.( Thanks, Bob) I like it because dual butter fly action. both barrels open at the same time for increase power. I installed electric fuel pump to stop vapor lock. and jetted down the mains to 135 and the air corrector 160 and been running great for years. Would never go back to 32/36
This is as much power you can get without going FI.
I would Trade you for a nice 32/36 if your 38 is not in too bad of shape.
Mike
MIKE
1969 Opel GT in Paint Shop
1973 MGB, Red, Weber 38DGES
I have pride in my rides
opellane is offline
Old 12-19-2007   #9 (permalink)
G54B-GT's Avatar
Swap
Thanks for all the feedback, I have been working with hrcollinsjr (opeler) on a swap for his 32/36.
If this were mine I would tune the 38 for max. power and run with it, but for my moms little grocery getter she doesn't need the extreme.
I Will let you all know how it works out as well as posting pics of the build up on her car!
G54B-GT is offline
Old 12-19-2007   #10 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
You know, in Denver you might actually have a better chance of it running well than those of us down low would. Not that I could help you tune it, but it makes sense that if you were going to use that carb on a stock motor anywhere, it would be up high where less actual would get sucked through it.
oldopelguy is offline
Old 12-19-2007   #11 (permalink)
G54B-GT's Avatar
I was thinking that the problem would be not enough air here. Since the 38 is not sequential you are just dumping a "ton" of fuel in with not enough air to mix with.
I assumed a sea level guy with the added atmospheric air pressure would have a better chance.
Is there a flaw in my logic??
G54B-GT is offline
Old 12-20-2007   #12 (permalink)
Opelnut
opelnut_1's Avatar
Logbook Entries: 6
opelnut_1 is on a distinguished road
G54b-gt, I am in colorado as well an had a place in Boulder called slipstream auto tune duel 40's on a volvo. you might see if there still around I think they can set up any weber on any car for any application. just a thought
Rick
70 Opel Gt (about complete)
65 Fastback Stang (in progress)
98 Gsx-r 750 (SOLD !! )
07 CBR 1000rr (replace above)
opelnut_1 is offline
Old 12-20-2007   #13 (permalink)
G54B-GT's Avatar
Thanks for the tip! If I get stuck I'll look 'em up!
G54B-GT is offline
Old 12-20-2007   #14 (permalink)
Sort of...a 'bigger' carburetor is bigger in the sense of larger throttle plates. Therefore it administers more air. Fueling is strictly an issue of jetting. In other words, I can make a stock Solex run pig-rich if I wanted by rejetting, and at the same time I could stick a 4-barrel Holley 850 double pumper on there and make it run lean on a stock Opel just by changing jets.
Extreme examples, yes, but the thing to remember is a bigger carburetor means more air, not more fuel. Fuel is always adjustable regardless of the carburetor size, whereas the air is restricted by the carburetor size itself.
Old 12-21-2007   #15 (permalink)
G54B-GT's Avatar
I understand, thanks for the help.
If I had lots of time I would like to play with it, but I just need to get it ready for my mom ASAP so I will just swap the carb and try that.
Again, thanks.
G54B-GT is offline
