Old 03-13-2008   #1 (permalink)
moose3d is on a distinguished road
Unanswered: Which carb do I have?
Have a Gt with 1.9 and the carb needs to be rebuilt. The metal tag on it say Weber 711F FB. Is this enough info or dod I need some more info from it?
moose3d is offline
Old 03-13-2008   #2 (permalink)
jvandyke's Avatar
I googled it and ironically enough, ended up right back here! Post 14 of this thread.
jvandyke is offline
Old 03-13-2008   #3 (permalink)
Sparky73's Avatar
Real Name: Jon
Sparky73
I got the same thing searching on a bunch of different search engines. I found one other thread on a 350Z forum that someone picked up a car with the same carburetor, but still no information was given. Possibly post some pictures if possible. That could be very helpful!
Current
1970 GT; Under Construction
Previous
1969 GT; Street/Strip Project
1969 GT; Black Parts Car
1969 GT; White Parts Car
1972 GT; Red Parts Car
Sparky73 is offline
Old 03-13-2008   #4 (permalink)
jvandyke's Avatar
? The link I included says it's a 32/36 Weber DGV5A. I believe it. Pictures would confirm it of course. Sounds like the common one used for Opels, Moose, and the perfect carb for your car. Might need a rebuild, but other then a worn shaft, (I've read) they're bullet proof.
jvandyke is offline
Old 03-13-2008   #5 (permalink)
Diagnosis?
Many Webers don't need rebuilding, they just need to be correctly installed in the first place. That means sealing gaskets and other hardware connected to the intake manifold on an Opel, to prevent common vacuum leaks. In addition, ignition timing and other factors need proper adjustment, to get the most out of a Weber. Information is available c/o the downloads (dated June 2006) linked below:
Engine
Anonymous D is offline
Old 03-14-2008   #6 (permalink)
It's all here!
Engine
While the above is true and since you're now already here, you don't even really need to go off-site, as it's been discussed here in numerous threads almost from this site's inception!
A simple, quick use of the "Search" feature here using "weber 32/36" will result in pages and pages of results covering anything you may want to know - install, jetting, rebuild, air filters, etc.
Old 03-18-2008   #7 (permalink)
Weber Carburetor Guru
It is in fact a Weber 32/36 DGV. The 711F number is a number showing the carburetor being a factory Ford part.
bigjim5551212 is offline
