Unanswered: Car Won't Idle...Vacuum leak/carb prob? please help! -Dallas, TX-
Any ideas on what is wrong? Vacuum leak maybe? I searched the forums and did not see anyone having the same problem so I am not sure where to begin. Please help! Thanks, Brandon Last edited by brandonr1985; 04-25-2008 at 11:15 AM. Reason: spelling |
Whole new carb (even if it has issues) same problem, must not be the carb.
What's ignition timing look like? Did you do new points/condenser, dwell and static timing and all that? And of course check all for vacuum leaks. Little hose from valve cover, vacuum booster line to brake booster, vacuum advance/retard line to distributor. You can plug all of these last three off and see if the idle changes at all (don't plug the little one to valve cover.
#3 (permalink) | |
If you would like maybe give it a quick test, start engine and use a pair of vise grips and crimp gas line before the Carb to stop the gas flow while it's running and let it run off the reserve in the bowl and see if idle returns or if it runs better. |
UngerDog
Congrats on your new GT and welcome to OpelGT.com. I'm thinking that you probably do have an improperly adjusted float in the carb or the needle valve is not closing properly. You can test this by taking the fuel line off the carb and manually trying to add fuel (small squeeze bottle) to the carb. If the carb continues to accept fuel and/or leaks out of the upper carb gasket, you've found your problem. You can do a carburetor float adjustment search and find the proper adjustment instructions on this site. Also, vacuum leaks are a common issue and can lead to erratic idle and acceleration problems.
Jerry |
Im almost postive that gas seeping through is it perculating. It's common in opels. And this is caused because the gas inside the carb bowl starts to boil and therfore bubbles out. The most common sign is when you see like a mist forming inside the carb. Mine does it after engine warms up and i turn engine off. If it does start perculating you have to do 1 of 2 things. Wait till that gas evaporates OR hold your foot to the floor and hope your able to get it started but this may cause it to flood worse.
One of my friends on this site told me to run my fuel line underneath the front crossmember to the carburator so its off the engine and not absorbing heat. I have not done this yet but it is a good idea. Try doing that and it MIGHT solve the problem. I've replaced every hose, got a new carb, adjusted carb everyway in the book, played with timing, ALMOST everything possible and it still boils away. I have not relocated the fuel line so you might want to try doing that first and see if that solves the problem.
#8 (permalink) | |
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 04-26-2008 at 07:03 PM. |
I have my fuel line running straight through the radiator firewall where some wires were already going (right below alternator and such) then across the nose and back through the opening for the air filter snorkle then to the carb. I moved the fuel inlet to the outboard side of the carb (your's probably is already there).
I got the glass fuel filter on it already and it didnt help none. Like I said only thing I havent done was play with the actual fuel line
Years ago when I was having problems with my GT not starting on occasion I tested the fuel pump pressure and found it to be within specs pressure wise. Later on I pulled a new looking fuel pump from a parts car and installed it. Problem solved. FWIW, I never changed the routeing of my fuel lines or added any type of insulation to them.
Harold |
Weber Carburetor Guru
I would bet 5 cents its this problem
1) There is a vacuum leak from a brake hose, or a crack in a manifold or the base gasket on the carb is shot. Even a bad intake manifold gasket will do this. if there is a spacer on the bottom of the carb, that could be leaking as well. |
