Real Name: Wes Thomas
Unanswered: intake temp....
You would think that the hottest it could ever get is just above 200 degrees. This would happen just after the engine is shut off and heat soaks into it from the exhaust manifold and head. While running it should be cool as it's got lots of air flowing through it.
Just Bolt It!
Any "loose" stuff inside intake manifolds ends up inside the motor!
Then gets hammered into the valve seats and/or trapped between the piston top and the head. There is very little air flow on the boundary layers anyway - so 'blending' does very little to help air flow ... it is the basic shape of the 'tent' which has the most effect. Its major purposes are to simply reduce plenum volume and direct liquid fuel away from the intake manifold bottom. A bit of turbulence is good there to help get any fuel back into the air flow.
So Jim, if my sculpted tent is a close fit, and the sides are concave, then I should just bolt it in and call it quits? I can do that! What should be done about the vacuum port that connects to the rocker cover? It will be blocked when the piece is installed. I haven't been able to find a post that addressed that issue. Maybe a groove at the end of the piece, running perpendicular to the port, that will be open to runners 1 & 4? it's just a wee hole that comes thru. There may be just enough gap at that end to suffice. Any problems there?
Opel Mystery ...
One hesitates to call the CIH motor internal ventilation system "positive" - one of the great Opel mysteries is how it actually works ...
Guess that wee port inside the intake plenum does need to be open to the cylinders ... just a wee bit cut off the end of the 'tent' or a groove filed along the end should work ... (er ... may work!) ...
The hottest the intake will get is after you shut off the engine. How hot? Hot enough to instantly boil water if you spill it on the intake, and hot enough to eventually loosen epoxy after enough heat cycles.
