Unanswered: Weber Hard Start Warm Problem
Proud Original Owner of a 70 GT Not pumpkin ORANGE no more though !! |
Mike's Opel Shop
Vapor Lock
I have a Weber 38 DGES on my GT, I use to have that problem too, But since I re-routed the fuel line under the car away from any heat source and added OGTS Electric Fuel pump, near the fuel tank. (blank plate where Mech. pump was) I haven't had that problem in years, starts first crank after being driven. These cars are known for vapor lock. (under hood temp gets very hot after you turn off motor) A preasurized fuel line is hard to have vapor lock.
Just my .02 cents worth, works for me.
MIKE --------------------------------------------------- 1972 Opel GT,Citris Yellow 2.0L, Weber 38DGES 1969 Opel GT in Paint Shop 1973 MGB, Red, Weber 38DGES I have pride in my rides
#3 (permalink) | |
'72 Opel GT (Sara)
HTH Matt
Thanks for the ideas. I will try these starting (of course) with the easiest (and cheapest) first to see how it goes.
It's usually not too hot here in Minnesoata, but it sure is hot under that hood! Thanks Again guys.
Sounds like a fuel foaming problem to me.
Vapor lock is the fuel boiling before the fuel pump. Fuel foaming happens in the carb bowl adding pressure on the jets. The solution is to try all of the above then try.. thicker carb spacer heat shield Blower across the intake A electric supply pump with a with a return line to cool the fuel. The more the alcohol content of the fuel the more problems you'll have in the summer. See "reed vapor" Hope this helps |
Since your carb is dumping gas down the throttle, I don't think you have a vapor lock problem (not enough gas due to air bubbles). I suggest checking correct float bowl level (41/51mm).
I just installed a brand new 38 Weber with the same symptoms, and the float bowl adjustment fixed it (besides rejetting for optimal throttle response). Dieter |
flooding?
If you see liquid fuel in the carb. at idle you have a flooding problem, maybe a new needle valve, float level wrong, float with gas in it, etc. sounds like it's hard to start due to an over rich mixture on a hot engine.
You got it on the rich flooding part. But, this is not at idle. Car idles fine. It's after driving it when it sits for a couple of minutes. Then the fuel just starts percolating into the primary chamber. It's a new Weber 32/36 carb from OGTS and today I just rerouted the fuel line around the hot part of the engine way up in front of the radiator. That went fine, but it still does it. I hope it's an adjustmnet issue as you all say here...float level etc. That's my next step. Tks.
#10 (permalink) | |
I'm in MI where we have 10 percent ethanol in all the gas and I'm convinced this (and maybe other fuel additives they don't tell us about) is the cause. I do find some improvement if I burn premium. A sprint manifold would probably help, but hard to find and costly. Fuel injection would no doubt eliminate the problem all together. Today's gas ain't what it used to be. Don |
#11 (permalink) | |
#12 (permalink) | |
TMK |
#13 (permalink) | |
All you guys are right !! Great help
I had a carb guy look at it today and he said that simply put it's too hot under there. He says the fuel is boiling and the accelerator pump jet is the one that is dripping the most into the chamber. He suggested 2 things...(1) try non-oxy fuel (like you suggest DCM). Sounds like you've found the premium might have an even lower boiling point. He also suggested a blower fan (boat vent type) mounted up front in the void space and then ducted back to the carb. I seem to remember that in these forums and will check this out. I'll also study the sprint manifold as a Winter project too as suggested. Thanks from Minnesota. The good news here is that it's mostly WINTER most of the time!
Great to hear your getting closer.I hear good things about the aluminum radiators reducing temperatures.I'm not in a real hot area either (Vancouver Island BC) but with 30 degree celcius plus temps right now i have no overheating fuel problem.I have the sprint & didn't use the heat sheild. 160 degree thurmostat. keep us posted.
#16 (permalink) | |
I hadn't thought about a boat vent fan but it sounds like it may work. I've got the stock air cleaner on my GT so I'm not sure where the ducting would fit. Lots more space on the Manta - I can pull air in through the original cold air intake in the grill. What about a temp. sensor to turn it on only when needed and a timer to run it for a bit after shutdown? Don |
Weber Carburetor Guru
I think your choke is coming on too fast. I mean, the choke goes on, when the engine is still relatively warm. You need to loosten the 3 screws holding on the choke housing and make it so the choke plates have some resistance when you push on them when the engine is off and the choke is cold.
You might also check into getting a phenolic (a composite material) spacer. The spacer insulates the bottom of the carb from the intake manifold and can make a huge difference if you are experiencing the fuel boiling problem. Generally though if the intake manifold is getting that hot there is usually another problem.
You might also see that you are not running way rich or have you timing way advanced causing your exhaust to get really hot due to burning fuel entering the exhaust manifold. Nathan Acree Albuquerque New Mexico |
#21 (permalink) |
This summer for the first time since I have owned this car from 1971, the fuel is foaming (boiling) in the carbuetor bowl even though EVERYTHING electrical and mechanical checks out ok. The idle stability comes and goes when the ambient air temperature is above 80 F. This only started when I topped off the tank that had 7 gallons of winter gas left with premium summer gas. Since then I tried regular summer gas (same brand as the premium Mobile) with the same idle issue. Turns out summer gas has a lower vapor pressure (less than 14.7 psi) than winter gas (greater than 14.7 psi) to help minimize air polution, etc. I am actually starting to wonder if this year's summer gas has a new formulation and optimized for fuel injection. I will know when I get a chance to run this car on BP summer gas and BP winter gas late this fall. Also, I am wondering if different brands have different formulations for summer gas which may effect Opel idle. The last 2 tanks were Mobile. Before that (last year) I was using BP, Shell and Marathon without any idle problems. Thinking maybe we should start a thread listing gasoline brands where we are having problems and not having problems.
#22 (permalink) |
It's a Gas!
You might have something there. In Minnesota the Minnesota Hot Rod Association posts stations that sell non-oxygenated fuel. Next time I fill up that's where I'm going to get something without ethanol in it. Hopefully that will help.
#24 (permalink) | |
![]() My Opels have suffered this problem during extended idle conditions for the past few years, despite which brand of gas I use. Keep us posted if you find a brand that works better! Don |
#25 (permalink) |
Mike's Opel Shop
Summer re-start problems
I've owned my GT for along time now ( since 1995) and I got sick of sitting in the Gas Station right after a nice drive. While everyones watching your neat car, and then just let the starter sing.
Aren't we making Fun.So I got the Electric Fuel pump, and mounted it near the tank, and ran new 3/8 clear hard plastic tubing up to the Carb. with a Clear Fuel Filter (the fancy Glass kind). So, Now when I turn off the car, I'll give a minute or two. The fuel Psi is still at 3.0 lbs or so. The new Fuel Pumps all got check valves in them, Now the Vapor/ Alcohol what ever, probably won't boil now. It's preasurized some what. Your Mech Fuel drops to Zero 0. Turns over on very first click. Rummm or if your worried key over 2 sec then GO.I telling you it's amazing. And I had this Problem for years and it drove me crazy for year after year., You might want to try it, It's just some tubing, a Fuel Pump and some wires. IT WORKED FOR ME. ![]() If you Install a delayed or T-stat electric Rad. fan will probably do the trick too. But I think this would make more sense. But this is only from my experences. By all means you ALL do what works for you.
