Unanswered: Weber Gas Return Line
101st Airborne Vet V.N.
Real Name: Thomas Johnson
If I understand you correctly you had some concern about the fuel inlets on the left/right sides of your weber? It is your option, but most folks connect their fuel line to the inlet closest to the passenger side. Not the one closest to the valve cover.
Thomas |
Before I mounted the Weber, I tried blowing air in both of the inlets. Air moved more freely through the driver side inlet, so I reasoned this would be the correct side to hook up the fuel line. I capped off the other side, but if both sides are inlets, I'll swith to the passenger side inlet. Thanx!
It's also a good idea to remove the pressed-in brass fittings and drill and tap for an 1/8" NPT fitting with 5/16" barb.
It's actually required for most racing classes using a 32/36 Weber because they have been known to vibrate loose and the net result is raw fuel pouring onto your exhaust manifold! ![]() ![]()
#8 (permalink) | |
RallyBob..that carb looks sharp. I wish I would have known all this before I mounted the Weber. |
#9 (permalink) | ||
#12 (permalink) | |
Opel Intern
First, how do you remove that pressed in inlet? Second, may I only tap the resulting hole, or do i have to drill in order to have the proper diameter barb fitting in threaded in? Thanks |
#13 (permalink) | |
I drill the hole in the carb body to size, it's a bit small for a 1/8" NPT pipe tap. Never force the tap and use a tap cutting fluid if possible, otherwise the carb body may crack!
#14 (permalink) | |
Opel Intern
Now just so that I don't screw up, what size drill bit? |
I don't recall the size of the bit I've used in the past, however it was as big as it could be and still hold threads correctly. I just eyeball the tap and match a drill bit to it.
It's not a great picture. intake :: weber 32-3x picture by wrench459 - Photobucket
But you might get the idea. |
According to my tap drill chart, an NPT 1/8" tap requires a "Q" sized dill bit, which is 0.332", 8.5 mm, or or a tiny bit smaller than 11/32".
I have scanned and attached the Tap Drill Chart that came with my tap and die set for future reference. HTH
