Real Name: Wes Thomas
Unanswered: Carb loading
Please help! Wes |
whats your fuel pump ? weber's dont like much pressure and can flood out the carb easy
Float weight? I didn't know there were variables with weight. I can say that the float in this carb is not the one supplied originally. I pulled a brass one from an older Italian 38, and replaced the plastic float that it came with. Should I try the plastic float? Would it weigh differently? I got rid of my gram scale after college, so I can't compare them.
Well, neither the plastic or the brass float (both properly adjusted) made any difference. Don't know where to go from here. Six days til the meet, and not even close to having a running GT. Jeeeez....
Real Name: James
Wes,
I had the same problem with a 38 (new) a few years back before changing to a side draft. The same fuel pump that worked on the previous 32/36 would flood the 38 during idle. I tried different pumps, floats, settings and even tried a Grose Jet, which is a ball and seat that replaces the stem and seat...all to no avail. I finaly had to install a regulator that would bring it down to about 1-1/2 psi. I started track daying the car and would empty the fuel bowl on the 38 in 3rd gear so I installed a SSD 45 Weber and removed the regulator. The 45 didn't flood with the same fuel pump. I don't know if this is just common to the 38's, I never found a cure other then adding the regulator. Sorry. James
"If you have complete control of the car, you're not going fast enough". PARNELLI JONES 1966 |
James, thanks for your response. The regulator would be an easy fix. Did you have any problems with the 32/36 other than on the track? My GT is a only a street car. I am also working against the clock with only 5 days to solve my problem. I have had both carbs. The 38 seems to be easier to tune, so I would love to keep it. I'll try the regulator in the morning, and post the results. If it doesn't do the trick, I still have time to get a new 32/36 from OGTS before the end of the week.
What is your idle speed and what is your initial timing advance setting? Stock initial advance won't cut it with this set up. Once you've figured out what initial you need to run then you're going to need to figure out how you're going to limit your total timing advance. Been there done that with the Isky OR-66H cam in a 1.9 32/36 equipped car w/header and stock valves.
Harold |
What main jets, idle jets, and emulsion tubes you have in it?
#16 (permalink) | |
I noticed Opelwasp asked about your jetting. I think he may have hit on your problem. Harold |
Can you clarify your jetting concerns. I'm not the only member with a modified 2.0l, at sea level, using this range of jetting. I'll try anything suggested, as long as my mechanical abilities can manage the changes.
#18 (permalink) | |||
Harold |
#19 (permalink) | |
Harold |
#20 (permalink) |
Wrong, the 38 is a PITA to tune. I've had mine for 10 years and still haven't gotten it right. On small engines(1.9) it would flood and bog, on my big engine(2.4) it leans out at high rpm. I am so fed up I am switching to EFI.
When I did have it dialed in close it screamed.
#21 (permalink) |
I have tried the size 200 seat from a 32/36, but the carb was over filling and I couldn't tell if it made any running difference. Right now, I have 55 idle jets in it. Before the problem occured, I was running 70's with no problem. I think the problem came from rerouting the fuel line to the fender side. Last year, I replaced my fuel line, and routed it around the radiator to the fender and the to the carb. I was still using the engine side of the carb for inlet. Consequently, the fuel line had to make a tight radius turn to the nipple at the inlet. It's a rubber fuel line with a ss braided outer. I think the tight radius was pinching the line just before entering the carb., and the inline fuel gauge was plumbed ii just before the turn. It read 2.5-2.75 psi . Now my line is a straight shot into the carb. Maybe too much fuel pressure after that. I'm running to the store to get a regulator. Maybe we'll have an answer soon.
#22 (permalink) | |
Harold |
#24 (permalink) |
I just bought a $25 Spectre adjustable regulator that adjusts from 0-5 psi in 1/2 lb increments. It was all I could find in a short amount of time, locally. Autozone has them in their "performance" section.
