Answered: Carb on eBay
Most Helpful Answer - Posted by kwilford
You'll be several hundred dollars and many curses ahead by simply buying a proper Weber. If you aren't comfortable buying one from eBay, spend a few extra $ and go to Weber Carburetors,Carburators,Conversion Kits - Pierce Manifolds Inc. or Weber Carburetors Carbs 40 DCOE 45 DCOE 32/36 32/34 Jeep or OGTS or one of the other reputable Weber supply shops and they will spec out a Weber with jets that are close enough to get you in the ball park. Then further jetting can be done as or if required. HTH |
This is not an exact replacement, will it work? Who knows. For that kind of money, buy a Weber. Like this one: 160335728256, or this one 260420840079 or even this one 270400754430.
There are lots of them on Ebay, just search for Weber 32/36
Paul |
#3 (permalink) | |
Oh, and you'll need new gaskets for the base, and the old linkage ball and lever off of your old Solex, and an air filter or adaptor, and new manifold studs (the OEM studs are too long, although some folks work around them by either adding washers or cutting the old studs down) HTH
Thanks for the insight
Thanks for the insight. I may just let a local shop rebuild the existing carb. I was trying to save me money and them trouble (only the old-timers in the shop know about carbs). If this sounds like the wrong road to go down feel free to tell me.
The last Opel I owned was in the 70's. That experience inspired me to buy this one. Now I am finding that what I recall mechanics saying was an easy car to work on is not so easy because too many mechanics only know what the computer tells them. Thanks so much for all the help/advice. |
Carb. 101
#8 (permalink) | |
