Old 08-16-2009   #1 (permalink)
MonkeyNutZ's Avatar
MonkeyNutZ is on a distinguished road
Answered: Help Identifying Carbs
I'm trying to sell my two extra carbs to help fund my 73 GT restoration however, I have no idea what they could be.
If anyone wants ether of them before I put them on Ebay just shoot me a PM
Here is the Solex
MonkeyNutZ is offline
Most Helpful Answer - Posted by hrcollinsjr
Originally Posted by MonkeyNutZ View Post
And here is the Holley
Some version of the old Holley 5200 aka Weber DFV. IIRC they came in 3 different CFM's depending on the appl. They were used on a LOT of U.S. 4 cyl. cars from the big three, Ford, GM, & Chrysler. Tip: If you need an accelerator pump diaprhagm for your Weber DGV ask for one for the Holley 5200 instead and they'll probably have it in stock. Again, appli. Chevette, Pinto, Vega, Mustang II, etc.
HTH,
Old 08-16-2009   #2 (permalink)
MonkeyNutZ's Avatar
Old 08-16-2009   #3 (permalink)
Here is the Solex
I can narrow the application down some by the process of elimination. Water choke pre '73 models. Vacuum secondary eliminates GT application.
hrcollinsjr is online now
Old 08-16-2009   #4 (permalink)
HTH,
Old 08-16-2009   #5 (permalink)
MonkeyNutZ's Avatar
Thanks a ton, I got the ID tag on the Solex cleaned off and it only says "3441 510 D" Google wasn't very helpful on that front though. I don't have anything close at hand to measure the venturis with but I assume they're both 32mm?
Solex carburetors are truly frustrating, did they even have model numbers?
Old 08-16-2009   #6 (permalink)
1971 GT
CDN OpelNut's Avatar
CDN OpelNut
Looks like a 32DIDTA
CDN OpelNut is offline
Old 08-16-2009   #7 (permalink)
MonkeyNutZ's Avatar
It does indeed
Thanks to both of you, now I just need to grab something that has millimeters on it and I'll know exactly what CFM my Holley is.
Any thoughts on how much I should sell them for?
Old 08-17-2009   #8 (permalink)
...what CFM my Holley is.
I did find reference to two different size Holley's but I still believe there were three sizes.
Don't worry about measuring the size you are looking for is cast into the primary and secondary side of the carb. Primary side '23' equals 235 CFM and primary side '26' equals 270 CFM both measured at 3" of Hg.
