Old 09-17-2009   #1 (permalink)
robinspain is on a distinguished road
Unanswered: Standard weber jetting 32/36? What is it?
OK I have trawled the forums but help! can some on please tell me and hopefully others what the standard jetting for Weber 32/36 should be for the standard engine not the High compression one. People say it depends on altitude etc, but sorry that sound wrong to a point. Most people drive all over the place. I don't re-jet my carb if going on a trip from the coast to mountains, with a change mid way! Ok so there is a general compromise made by car manufactures to give and overall balance. It is this golden figure I am looking for, I want to replace the mangled solex for a weber, the shop said the would re-jet it for $3 from the standard ford settings. So what do I tell them. This is as far as I can make out the basic starting point from hours of searching but please chip in if you know:
32) idle 50 Main 135 Air150
36) idle 55 Main 150 Air 165
What are the emulsion tubes and what should they be: F50 /f55 ?
Please can some one give all us long suffering solex owners the definitive answer. I am sure this will prove helpful to many owners.
robinspain is offline
Old 09-17-2009   #2 (permalink)
SteveGT's Avatar
Real Name: Steven
SteveGT will become famous soon enough
here's what I run
primary idle(60)
secondary idle(50)
mains(145)
primary air(170)
secondary air(160)
SteveGT
'70 GT aka... Veronika
SteveGT is offline
Old 09-17-2009   #3 (permalink)
Hi Steve, is that for a totally standard engine? And is 145 the main for both?
sorry I just want to try to fit and forget the carb. With the opportunity of some one who knows what they are doing to jet the thing.
Cheers
Rob
Old 09-17-2009   #4 (permalink)
There is no "one" correct answer for all Weber 32/36's on all Opels.
Even when they were new, jet sizes varied with the various Weber series (Models 5A compared to 33b, for example).
Anonymous D is offline
Old 09-17-2009   #5 (permalink)
I was wondering about the Euro spec. on the Opels, wouldn't they be different than the state side cars?
I think that their fuel formulation is/was different.
Old 09-17-2009   #6 (permalink)
SteveGT's Avatar
Real Name: Steven
Possibly different Dan for sure....I tried 4 diff combinations till got it right...145 on both mains is what it came to....running too rich so I increased the primary air to 170...leaned it out...still maybe a little rich but wanted to drive it a while before any changes....my altitude is around 4200 has some do to with it I think...may go to 135 on the mains to see what happens...will post results gonna do it next week...too busy this week.....runs real good right now tho....I am at 34-36 mpg right now...highway of course..city is around 28-32...so real happy with gas mileage and performance but gonna tweek some more...SteveGT
Last edited by tekenaar; 09-18-2009 at 11:08 AM. Reason: to = direction; too = excessively
SteveGT is offline
Old 09-17-2009   #7 (permalink)
blancojp's Avatar
Provided Answers: 10
Cheers
Rob
If you are in Spain, all of the numbers we can give you will not fully work in your area. Your best bet is to find either a Fiat or a BMW shop and have them tune the carb for you. If you find someone knowledgeable on the tunning side of a BMW 2002I, he can jet the unit for you.
JB
'70 Opel GT - 4 speed "Lucy"
blancojp is offline
Old 09-17-2009   #8 (permalink)
Dale .D's Avatar
I took tekenaar's Suggestions & it's been great
Dale .D is offline
Old 09-18-2009   #9 (permalink)
Lightbulb Some jetting/altitude basics . . .
. . . air vs. main jetting effect on mixture is a 3:1 inverse ratio, i.e. increasing air jet 3 sizes (150 to 180) leans out the mixture the same amount as reducing the main jet 1 size (145 to 135).
SteveGT: suggest primary main jet reduction to 135, as you stated, for your altitude . . . both mileage and performance should improve. You might try going up one size (10) on secondary air, you're a wee bit "fat" there too, but not as critical as primary . . . use it 75%+ of the time in normal driving.
robinspain: good "starting point" for yours would be . . .
32) idle 50 Main 135 Air 160
36) idle 55 Main 150 Air 170
. . . close to last post's suggestion with small adjustment for Spain's average altitude.
Old 09-18-2009   #10 (permalink)
The one thing I found out was the water vapor content of the air.
It's a power killer in the early morning when the dew is heavy.
