Old 4 Weeks Ago   #1 (permalink)
robinspain is on a distinguished road
Answered: Help lost a nut!!!!!!
Hi can any one tell me what the origanal nut size is for the opel gt 1973 carb stud to mainfold. I was replacing the solex and one of the 4 nuts holding the carb down went walk about, 3 yes 3 hours with a metal detecter, torch, kids ect, no luck. Please can any on give me the specification, nothing I have fits. I thought it would be a metric 6mm but it seems to have a finer thread than normal. Please advise if you can.
Cheers
Rob
(cant belive I did this!!!!)
robinspain is offline
Most Helpful Answer - Posted by 2 Fast 4 U
The nut size is M8 x 1 mm pitch it has a finer thread than the standard nut [M8 x 1.25], try looking somewhere on the suspension or engine at least higher than the ground
Old 4 Weeks Ago   #2 (permalink)
'72 Opel GT (Sara)
newman27's Avatar
Real Name: Matt
I don't know the answer to the nut size BUT I can tell you where a lot of stuff ends up on that side of the car. There is a metal shield that runs parallel to the exhaust pipe just behind and below the carb. If you stand on the passenger side and look straight down behind the carb you can see it. I have dropped bolts, wrenches, and sockets down there in the past. Maybe that's where the nut went to...
Matt
'72 Opel GT (Fireglow Orange)
Restoration Thread
Comments Thread
Other Cars:
newman27 is offline
Old 4 Weeks Ago   #3 (permalink)
the lost nut
Hi Matt,
The heat shield was good point sadly I had moved the carb to the front being to lazy to undo the fuel pipe, and forgot the nut was stuck at the side of the carb, saw a pool of fuel in the intake pipe, then the thing dropped into scrub, like thorns to keep cats off. The car is basically stood up for sake of this one nut, I have tried to cut a new one but just cant fatherm the thread even with a gauge.
Cheers
Rob
Old 4 Weeks Ago   #4 (permalink)
2 Fast 4 U's Avatar
Opel Ascona;
Only built from 1970 - 1975
2 Fast 4 U is offline
Old 4 Weeks Ago   #5 (permalink)
Cheers for the reply, I cant tell you how grateful I am and how stupid I feel. The kids thought it would be fun to help out, I think I have put them off cars for a few years!!!!!! They now think a metal detector is mandatory, and a simply job will take well over 3 hours.
I have searched higher for the nut, but no joy. Still I will try to track a new on down, and a few spares.
Cheers
Rob
Old 4 Weeks Ago   #6 (permalink)
Cheers
Rob
I know you have fastener houses over there, but, if worse comes to worse, go to www.mcmaster-carr.com they would have it, and probably ship you a handful, or a boxful Here's the link to the 8mm nut you need:
McMaster-Carr
Old 4 Weeks Ago   #7 (permalink)
Opelitis since 1984
GoinManta's Avatar
Real Name: Charles Goin
NAPA has them and shorter carb studs too.. When swapping the Solex for a Webber you want to put it 10mm shorter studs.
Charles
CURRENT
'06 Pontiac GTO
'74 Opel Manta (Bens Manta)
Past
'73 Opel Manta (Blue Max)
'75 Opel Manta (Yellow)
'85 Bitter SC
'73 Opel Commodore B GS
'73 Opel GT (w/ Vinyl Roof)
At least 16 or So Parts Opels
GoinManta is offline
Old 4 Weeks Ago   #8 (permalink)
Cheers for the link, have ordered a bucket load. I appreciate your time in helping out. I Cant believe one nut (well 2) brings the whole thing to a Holt.
cheers Rob
Old 4 Weeks Ago   #9 (permalink)
2 Fast 4 U's Avatar
Cheers
Rob
You're welcome
Opel Ascona;
Old 4 Weeks Ago   #10 (permalink)
Gordy's Avatar
Look down a block, on the corner, for that lost nut. There's more light there! Good luck getting 'er back together. I always take a nut or a bolt with me right up to a good hardware store and just say "This is what I need!"
Gordy is offline
