This carb was manufactured under license from Weber. It appears they may have taken some liberties with the design BUT the similarities are undeniable. The Holley/Weber/Motorcraft or even Weber DFV is easily distinguished from the Weber DGV series by two very obvious methods. The 5200/DFV is a mirror image of the Weber DGV. Not to worry, if you can't recall which side the primary is on for either Weber, just remember the the DFV has an oval or small ridge around the choke/air horn and the DGV is squarish with no ridge. When searching for info some described the ridge as 'football' shaped. :thinking:, DFV, football shaped ridge, I can remember that.
