#151 (permalink) | |
#152 (permalink) |
Certainly not. It has a stamp in it which I oriented the same way it was originally. At the time, I did try to get the plate centered, and I know it's not near the transition ports when closed. Another thing I thought about today is that the overly rich condition I'm seeing may be normal, because I'm opening the secondary by itself under a high vacuum condition. I even closed off the primary idle circuit when I did this test by backing out the primary stop screw. It's possible that under acceleration this would be a normal amount of enrichment because of less vacuum. Still, I'm going to double check the throttle plate to be sure it's not too far off, and also go back to a slightly larger main jet.
#153 (permalink) |
Real Name: Brian
I was asked to check if the idle jet is "physically larger than the secondary" before ordering new jets. Does anyone know if this is the case with a Weber 32/36 DGEV? or does this vary with the model type?
#156 (permalink) | |||
#157 (permalink) | |
Harold |
