Old 10-16-2005   #26 (permalink)
Bo Know's '69's
Bo Mows's Avatar
What is the gasket set up for the Weber starting from the intake to the base of the carb. I think i've got a bad vaccum leak between the heat shield and intake or heat shield and carb. What gaskets do i need in what order? The PO didn't have the carb tight, just sitting on the intake.
Bo
Bo Mows is offline
Old 10-16-2005   #27 (permalink)
got to get you guys and gals to use the search engine it gets you things like
http://opelgt.com/photos/showgallery.php/cat/539
which should be a good start to fixing air /vac leaks
Old 10-16-2005   #28 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Baz, I used that on my hose setup, but i have not found anywhere the placement of the gaskets and spacers for the mounting of the carb to intake. Really, i've looked. Maybe i just have not used the right search word combo yet.
Bo
Bo Mows is offline
Old 10-16-2005   #29 (permalink)
Gasket stack ...
Manifold - paper gasket - heat shield - paper gasket - insulating spacer - paper gasket - carb.
That is why the studs are so long!
Old 10-16-2005   #30 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Thanks here is a picture of the carb with questionable hoses. There is no charcoal canister in the car. I think the PO tried to route around it. Hoses don't fit where the diagram in earlier post say they should go.
Bo Mows is offline
Old 10-17-2005   #31 (permalink)
Bo Know's '69's
Bo Mows's Avatar
Here's a pic of the carb. The label saying 2 lines going to distributor are the 2 lines going to front and back of vaccum advance. So there are 3 vaccum lines here, brake booster vaccum advance and retard. This doesn't seem right to me.
Bo Mows is offline
Old 10-17-2005   #32 (permalink)
Thumbs up Manifold-to-carb stacking order
If you follow that stack-up, you won't have any fuel bowl percolation problems . . . even if driving in Texas summer heat!
Old 10-10-2007   #33 (permalink)
andrericardo is on a distinguished road
are the DGV series carbs Bolt-on the manta 1.9 inlet?
andrericardo is offline
Old 10-10-2007   #34 (permalink)
Yes
Yes, the Weber 32/36 DGV 5-series, 5-A series, and 33-B series
(as well as the 32/36 DGEV and 32/36 DGAV) will bolt up to a
1.9 Manta manifold (although you'll need to adapt the throttle
linkage and air filter).
Additional instructions are here:
http://www.opelclub.com/TuneUpPart1bJune2006.pdf
Anonymous D is offline
Old 05-04-2008   #35 (permalink)
I don't know where to post my questions but this looked like a good spot.
How much milling of the choke housing before ventura booster problems? (32-36 DGxV)
I need air and lots of it under the confines of the GT hood.
Also is the 32-36 choke housing interchangeable with the 38 DGxV?
Old 05-04-2008   #36 (permalink)
gt crazy's Avatar
If you want a carb that you can just put on and not worry about jetting and all that fun stuff, you need to go to OGTS. I got my from them and it works GREAT! Very great quality. I think I paid 383 for the carb all the linkage things gaskets and the chrome air filter. WORTH EVERY PENNY!
gt crazy is offline
Old 07-17-2008   #37 (permalink)
Weber Carburetor Guru
the answer is YES for the choke question. With regards to milling, you dont want to mill that housing. that gives more air into the carb
bigjim5551212 is offline
