long time Opeler
That really depends. Dual 45 Webers can be tuned to run on a stock 1.9-2.4. The right venturi's with the correct jetting, almost anything is possible. 45's would not be my first choice.
45's are the minimum I would use with a 2.4 CIH engine. 48's would be better, especially if you have higher compression and a hotter cam. But as Deaner said, they can be tuned to work with many applications depending on venturi size and jetting. 36 mm venturis on a completely stock 2.4 will run just fine.
Bob |
45 Dcoe
Based on a STOCK (i.e. mild) 2.4L motor, try these to get you started:
CHOKE - 36mm AUX CHOKE - 4.0 MAIN JET - 140 IDLE JET - 50f8 EMULSION TUBE - F2 AIR CORR. JET - 160 to 180 ACCELERATOR PUMP JET - 40 or 45 Anyone chime in if any of these look off, you won't hurt my feelings! ![]() For a more aggresive setup based on 600cc per cylinder (top end power): CHOKE - 38mm or 40mm AUX CHOKE - 5.0 MAIN JET - 150 or 155 IDLE JET - 60f8 or 65f8 EMULSION TUBE - F2 AIR CORR. JET - 180 to 200 ACCELERATOR PUMP JET - 45 or 50 Last edited by ConreroGT; 05-25-2006 at 10:21 PM. |
The forty eights seem to work ok.
http://www.cardomain.com/memberpage/470044 |
