Supercharged 2.4
Unanswered: Can anyone tell me what this is?
![]() Thanks! |
That is a single side draft carburetor, I doesn't look like a weber but may be a solex or del'orto.
Viking
Real Name: Hallgeir
That is opelgtworld`s GT I believe. He is a member here:
http://www.opelgt.com/photos/showpho...ser/15664/sl/o
#9 (permalink) | |
The picture above is a "SSD", better known as a Single Side Draft set up. It uses a two barrel carb, but that is the only similarity. Both throats operate simultaneously. The air direction is a "straight shot" at the valves. Most common are the Weber DCOE's and DCOM's, but the Solex and Dell'Orto are also highly thought of. A higher performance set up is the "DSD" as in Dual Side Draft. Dual two bbl carbs, so each cylinder gets it's own throat. Better at higher rpm, but more difficult to tune for low and mid-range. Also takes up more room, so requires extensive modification of the heater box area (at least with the non-shorty manifolds) in the GT. Time for you to do a bit of reading and research, as there are lots of good threads with lots of good photos on the site of all of these set ups. What kind of carb does your GT have?
Where did you get the linkage with the return spring? I've only found a couple of places to source that item. With the Solex, does the cable pull up as on the Webers? That is one of the stumbling blocks I have not been able to figure out. The linkage from here UNIVERSAL CABLE KIT is one thought that came to mind as well as here, Weber Carburetors, Conversion Kits - Pierce Manifolds Inc.
Thanks, Jarrell
You lose your dreams, you lose your mind. (The Rolling Stones) Last edited by soybean; 01-28-2007 at 10:15 AM. |
#13 (permalink) | |
www.opelgtworld.de
Solex DDH 40 Mac Gyver Is This a Volkswagen? Basic Jetting for the CIH 1.9: main jet 155 air jet 160 idle jet 65/115 accelerator pump jet 50 emulsion tube 27,5 ignition timing 6°
"Man kann ein Auto nicht wie ein menschliches Wesen behandeln - ein Auto braucht Liebe. (Walter Röhrl)" |
1971 GT
opelgtworld,
I am in the process of putting the exact same set-up on my GT. 40DDH from a K70 on an Irmscher short SSD manifold. I would appreciate any photos you have of this set-up from the linkage to the vacuum tubes etc. I thought was on my own! Send pictures! Corey
