Dr Evil
Unanswered: how to pick side draft maniflods for the GT??
I'd like to get a set of weber 40 DCOEs for my 1.9 GT,...I think I understand that there is a clearance issue with the heater box with this configuration. Are there manifolds that clear? Which kind/manufacturer are they from? Any mother hood? I feel comfortable with webers and have had many IDFs and other downdraft models on cars before,...but never messed wth sidedrafts,...the principles are the same but I am wondering about a nice set-up for street driving. Last edited by tekenaar; 08-11-2007 at 07:20 PM. |
For side drafts on a GT, basically you have two choices. A Single Side Draft (SSD) manifold and carb or the short runner lenght version of Dual Side Draft (DSD) manifold and carbs.
Both versions are less than common and a bit pricey. It will take a bit of hunting to rustle them up but they are out there...
Paul Last edited by tekenaar; 08-11-2007 at 08:02 PM. |
#3 (permalink) | |
Not for the "faint of heart"!
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 08-12-2007 at 02:35 AM. |
Dr Evil
I want dual 40's and understand there are multiple manifolds,...since the GT has the engine canted and ??? the Manta doesn't?? do I need to be concerned that they are Opel "GT" specific? This is all conjecture on my part. Standing by for corrections.
Wagerton;
I don't think there is any SSD that will fit the GT without heater box mods. But, on the DSD, there are "shortie" versions that will fit, but, you'll need to get real creative on the cold air box to make it all fit.
Gt and manta intake difference
you're right about that, there's a difference of 7 degrees between the two. I have a set of cannons that were made for a GT and I took 7 degrees from the carb side to bring them DOWN to level. hope that helps.
I thought the beauty of the SSD was that it fit the GT without mods to the heater box, but gave up some in the flow department.... No?
Paul Last edited by tekenaar; 08-12-2007 at 02:43 AM. Reason: with out |
I found a manual at the local liberary called " how to rebuild and power tune weber and del'orto side draft carburetors". in the fuel management, air filter and ram tube section it goes into choke selection, idle jet selection and main jet selection depending on per cylnder displacement and well as cam selection. cool book.
#9 (permalink) | |
You may be right, I just remembered Otto's SSD set up...my bad.
"Yes, I do have a rifle rack in my Sportwagon" Last edited by tekenaar; 08-12-2007 at 03:21 AM. |
Dr Evil
Just to be on the record, I definitely want DUAL Side drafts, 4bbl in all...any name brand manifolds that I need to search EBay and other sources for,.... Irmschler? (sp?) Are any of these available in the USA or are they all import and subsequently harder to get? Sounds like I'll want the "shorty" version. Because it sounds like I will not have to chop into the heater box with the use of those.
#11 (permalink) | |
. . . good call, Gene . . .
. . . you've just got SSD vs. DSD backwards . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 08-12-2007 at 03:20 AM. |
#13 (permalink) | |
#14 (permalink) | |
Flashspeed Opel GT
Aftermarket Side-draft carbs forum
You may want to see my postings on the 'after market side-draft carb forum' on SSD and DSD Steinmetz. Thanks |
#15 (permalink) | |
Anyway - what bits do I need to find / buy in order to achieve a setup like this? Its a Steinmetz manifold... Whats the carb? I should point out, that this is my first ever car with a Carb instead of fuel injection.... so this is going to be a steep learning curve. At the moment, I understand from reading around on this and other forums that what I want is twin side draft carbs, but on the Opel GT that is complicated because of space problems. So a single side draft carb sounds like an easier job for me. Is this set up built specifically for a 1.9 CIH or is the manifold from something else? Thanks Dan |
#16 (permalink) | |
Supercharged 2.4
#17 (permalink) | |
I don't know if a simple twin-choke webber single carb would do anything noise wise as that may be a simpler option!? As I said before; I really know little about carburetors except the theory of how they work. As for sourcing parts from Europe. I live in the England, so shipping shouldn't be as expensive to me from Germany. I just don't really know what parts I am looking for? Are they only available second hand these days or is there somewhere still fabricating manifolds and the like? In terms of opting for the Single Side Draft as opposed to the Twin Side Drafts - it's more the complexity of getting it done, rather than the actual costs involved. I got the car cheap enough, so I am happy to spend a few £££'s on it getting it just right. I just don't want to run before I can walk in terms of attempting mechanical alterations. What I want to do is make a shopping list of parts that I need and spend the next few months enjoying the car and sourcing the parts... then do all the work over the winter months. |
#18 (permalink) | |
Supercharged 2.4
![]() It sounds louder than the stock airbox and is a lot cheaper. It is easier to install than the SSD carb and manifold plus there is no custom fab.
