1971 GT
I finished the matching of my SSD manifold to the carb barrels as detailed in another thread. Today I finished my cold air intake as pictured below. All good so far. Now the bad. The car ran when I pulled it in to the garage. Idled fine and cruised at top speed well. Low speed driving was a little jerky and I planned to change the idle jets after I finished the last two upgrades. Now, the car started fine and idles OK, but when I give it throttle, it basically revs to about 3000 rpm and then bogs and/or dies, especially under load. So, for you experts, could the changes I made with the porting and CAI make so dramatic a difference? I'm not talking small effect, I'm talking undrivable! This is on my 2.4 with the DCOE45. The jets I started with are:
I was looking forward to this drive. It's been weeks!
Dry Gunk?
If you put the carb aside with fuel in it and that dried pout the emmulsion tubes may be clogged up with white powder = pull one and check the holes and the jet.
1971 GT
Well, I pulled off the cold air intake and then set up the carb again. It seems to run OK now.
Any chance that the CAI doesn't flow enough air? Seems unlikely as a 3" intake supplies some high HP cars. Filter maybe? I'll put the CAI back on tomorrow and then try again. I don't want to waste all that time! BTW - The tubes and jets had no crud in them but the drilling on the tubes was pretty rough so I cleaned that up.
Opel Intern
When it revs to 3,000 and beyond, how fast are you getting there? Does it bog right away or simply when it is above that rpm? If it is right away, it is most likely the accelerator pump circuit. If it is simply when it is above that rpm, you will most likely have to re-jet to get the fuel-air mixture right in the top end.
HTH |
101st Airborne Vet V.N.
Real Name: Thomas Johnson
Not any experience with a weber side draft, but what you seem to be describing along with what Jay said is fuel starvation????
The cold air intake is right on with the filter placement, and three inch airway from the carb opening and tube. This is right up Otto's alley.... he has this setup!!!!! Talk to the MASTER!!!!! ![]()
Thomas |
I would attach just the air box and try a quick run, then add the hose and do a quick run and finally the filter for a quick run and see when the problem comes back
"The nice thing about standards is that you have so many to choose from" --Andy Tanenbaum-- Last edited by ggl; 09-06-2009 at 06:03 AM. Reason: spelling |
#8 (permalink) | |||
1971 GT
It seems to improve as it gets warm. I've the weather dries out today I'll go for a road test and see what happens. Thanks for the replies so far. keep 'em coming. Corey
Real Name: gerold
Corey, You might want to get an air fuel ratio guage that works with an oxygen sensor. You have to weld a bung into your exhaust pipe and then screw in the oxy sensor and wire the rest. You could make it temporary and then take it out and screw in a regular spark plug to seal the exhaust hole. Anyway, I ave a similar set-up, and it tells you exactly how lean/rich you are at any time. Find a nice steep long hill, and you will have a poor man's dyno. Be sure to start rich and lean from there- better than burning up your motor. good luck, gerold
#10 (permalink) | |
1971 GT
![]() I'm looking for a deal, but will get one soon so I can tune it properly. I think maybe the additional airflow may be leaning it out too much now. Just found this quote on another site... "As a rule, no jet changes are required with just a K&N filter element, however the spark plug condition should be checked for proper mixture after the first few miles of riding. If the airbox has been modified for increased air flow, the main jet size will need to be increased to provide the proper fuel mixture." Hmmm C
1971 GT
Thanks Jim,
I have a set 4.5 aux venturies that I can try. I also have the larger main jets you are sending and some idle jets to try as well. My a/f guage is on the work bench and will go in next week. Between all of that, I should get it purring. Corey
#14 (permalink) | |
1971 GT
It does not specify sensor location other than at least 18" from the exhaust ports. However, when I was looking at the K&N site, they said it should go just ater the collector on the header so that is where I am going to put it. Cheers
#16 (permalink) | |
OK, that said, I know you closely followed my CAI setup pictures I sent, but have you tried running the engine with just the slanted airbox removed from the carb adapter plate to determine if there's a restriction at the rear carb throat? Can't really tell from your pics how much of the lip you cut off when fabricating that piece to make it fit, looks OK, but . . . ? Another observation, actually two, how are you sealing that slanted airbox to the adapter plate? . . . and, do you realize how much heat that glass fuel filter will absorb while engine is running? Small volume inside fuel filter will also exacerbate fuel heating! Better idea would be . . .
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-15-2009 at 11:59 AM. Reason: add pic |
#17 (permalink) | |||
1971 GT
Without the filter, my braided line from the tank isn't long enough! I'll watch it and can remove it if it boils. Thanks Otto. Corey
#18 (permalink) | |
Oh, added pic of better fuel filter location to my previous post . . .
