Dual Sidedraft Carb Set up
Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Like Tree1Likes
Thread: Dual Sidedraft Carb Set up
    First Time Opeler
    Dec 2009
    Springfield, VA
    9
    Daniel Sullivan
    Hello all,
    I just purchased a dual side draft Weber carb setup fpr my '70 gt on ebay. It arrived with what looks like all the parts needed to do the deed but no instructions. This setup is from cannon I think. Does anyone out there know where I can find some instructions? Thank you all
    Jul 2005
    Milner, GA.
    11,218
    Dan
    12
    Quote Originally Posted by dragonswar84 View Post
    Hello all,
    I just purchased a dual side draft webber carb setup fpr my 70' gt on ebay. It arrived with what looks like all the parts needed to do the deed but no instructions. This setup is from cannon I think. Does anyone out there know where I can find som instructions? Thank you all
    The DCOE's really needs a expert to set them up properly and I'm not saying that include's
    myself.
    boomerang opeler My location baz's Avatar
    Jun 2002
    sunderland england
    5,580
    barry williams
    If you need to ask then it's no good fitting them , pop then in a box wrapped up well in bubble wrap and send them to me , I'm sure I can find a nice home for them some place
    as Dan says theres no real way to set them up unless on a dyno to get them right
    There are a few million posts on jetting for them in here , have a search to find one with your engine spec and check the jets and emulsion tubes are the same , this will get you close . after that its best to find a shop that knows how to set them up on a dyno and have them fine tuned
    thinking about it don't send them to me , the one I have is used as a door stop and I'm running out of doors I need to keep open
    Copyright © 2003-2012 barry williams
    B.O.O.B. founding member
    Aug 2006
    Goderich, Ontario Canada
    2,647
    P.J.
    Hello all,
    I have a lot of good material on this subject but before I send it, please inform:
    - Is it a single side draft carburetor or dual (2) side draft carburetors set-up?
    - Which model? I assume DCOE.
    The DCOE's really needs a expert to set them up properly.
    Agree.
  7. #5
    '72 Opel GT (Sara) My location newman27's Avatar
    Jul 2006
    Atlanta, GA
    2,115
    Matt
    Sweet!
    If you do get it all working please post photos - dual side draft carbs is one of the sweetest looking things you can add to a GT engine IMHO.
    '72 Opel GT (Fireglow Orange) "Sara"
    Major Mods: Weber Carb, High Compression Pistons, Electronic Ignition, Custom CAI, Sprint Manifold,
    Enhanced Suspension (Anti-Sway Bars / Koni Reds / Sport Springs), "Big" Brake Package with 22mm Booster / MC, 15x8" Wheels and Toyo RA-1 Tires, XM Radio
    Restoration Thread
    Comments Thread
    Other Cars:
    '09 Pontiac G8 GT (Panther Black) "Jet"
    '06 Pontiac Solstice (Envious Green) "Mina"
    '99 Oldsmobile Intrigue GLS (Black Onyx) "Raven"
  8. #6
    Plano, TX 75074
    5,296
    Otto
    Red faceThread title says . . .
    Agree.
    . . . and I quote "Dual Sidedraft Carb Set up" . . .
  9. #7
    Aug 2006
    2,647
    P.J.
    Otto, they are all DUAL (double barrel). I wanted to clarify if it is one (1) or two (2) dual carbs. It is the matter of wording.
  10. #8
    Plano, TX 75074
    5,296
    Otto
    Question
    That is indeed what the general 'side-draft' consensus is, all two-barrels! This is not strictly true, of course, witness the single-barrel side-drafts by Carter ('53/4 Vettes and '60s Corvair Turbos) and all the SUs used in most '40/'50/'60/'70s Brit cars and Japanese copies, '60s Datsun Roadsters and '70s 240Zs come to mind.
    So, not to put too fine a point on it, P.J., but it's this very assumption that makes it somewhat moot, IMO. I mean, have you ever heard anyone ask about a dual 'dual sidedraft' carb setup? I certainly haven't . . . it's automatically assumed to be a dual two-barrel sidedraft carb setup that's being discussed, no?
  11. #9
    Jun 2002
    sunderland england
    5,580
    barry williams
    naught corner for the 2 of you
  12. #10
    Plano, TX 75074
    5,296
    Otto
    Quote Originally Posted by baz View Post
    . . . it all comes to naught I guess!
  13. #11
    Aug 2006
    2,647
    P.J.
    IT IS ALL OTTO'S FAULT!!
    Back to the thread now:
    Hello all,
    This http://www.webcon.co.uk/weber/40dcoe.htm link will give you general understanding of Weber DCOE carburetor.
    I have also attached the article that I saved from some Internet site years ago on jetting of Weber carburetors (hope it is not copyrighted). The article that I attached will give you general direction but unless you are very lucky, count on many try and fail attempts.
    You should also check several articles in this Forum.
    Your best bet would be to install the carburetors and to find out if they have street or competition set-up, are there any flat spots, etc. This will determine your further jetting steps. After playing with Weber DCOE carburetors for the last (AHEM) 40 years, I can confirm that almost each car has its own "sweet spot" set-up. I collected quite a number of jets, venturi tubes and emulsion tubes as a result of various attempts to find setting for my GT that will be to my liking.
    Finally, I have attached the file showing various settings that worked for me or for other members of this forum. You might still have to find your own, different setting.
    Attached Files Attached Files
    m610 likes this.
  14. #12
    First Time Opeler
    Dec 2009
    Springfield, VA
    9
    Daniel Sullivan
    Ok to clarify...
    I have a dual 2 barrel weber DCOE 40 carb setup with cannon manifolds....Real Italian Webers too. That being said...I appreciate all the info on how to tune them....but I need to know how to Install them. Does any one have this info? If you do please let me know. Thanks all of you for your help.
  15. #13
    Jul 2005
    Milner, GA.
    11,218
    Dan
    12
    Ok Daniel
    Maybe its time for you to upload a picture of everything that you have. That could/would help out tremendously.
    What do ya'll think start from the beginning?
    Understand that the mounting is just the tip of the iceberg.
  16. #14
    New/Old Owner 1973 GT My location JimVonBaden's Avatar
    Dec 2009
    Vienna, VA
    860
    Jim
    Daniel,
    I live in Vienna, VA. I might be able to assist in the installation. The tuning, however, is probably beyond me. I can get it running, and close enough to drive, but that would be it.
    Jim
  17. #15
    Certified Opelholic davegt27's Avatar
    May 2002
    San Antonio, TX
    1,270
    joe blow
    Hello all,
    Not too hard to setup but I would recommend a good Weber book
    basically what you're going to do is check to see if the carbs need to be rebuilt
    check the size (write down) of all the components
    set the floats
    bolt the manifolds onto a dummy head (if you have one) so you can check and see if all the butterflies open at the same time
    pretty logical and straight forward
    the Weber book will give recommended venturi size and aux venturi
    basically your going to check out the carbs and then just try them
    good luck
    Davegt27
    Last edited by tekenaar; 04-20-2010 at 01:14 PM. Reason: to hard, where to? ;-); your - possessive
  18. #16
    Jul 2005
    Milner, GA.
    11,218
    Dan
    12
    Quote Originally Posted by davegt27 View Post
    ... so you can check and see if all the butterflies open at the same time
    good luck
    Davegt27
    Hey Dave
    Glad to have you on board in this discussion.
    One of the special tools which can speed things up a tad is a unisync.
    From my experience thats the one thing that's always off.
  19. #17
    May 2002
    San Antonio, TX
    1,270
    joe blow
    Hey Dave
    dont use a unisync they work like crap
    http://www.thesamba.com/vw/classifie....php?id=554213
    get a "Flow Meter, -Synchrometer, Carburetors"
    http://www.englishparts.com/products...4/375-321.html
    good luck
    Davegt27
  20. #18
    Jul 2005
    Milner, GA.
    11,218
    Dan
    12
    good luck
    Davegt27
    LOL a manometer is just a thing.
    Can they measure the air density,moisture and temp?
    How does this relate to the post?
    I've seem A/F rock from 13:1 at 70 F to over 14:1 at 40 F
  21. #19
    No....its not a Buick.... My location yellaopelgt's Avatar
    Feb 2005
    On Wind Lake WI.
    1,511
    Joe
    If memory serves me, I do believe the Cannons do have the best flow. But...they are longer than the Irmschers. Therefore, some major surgery of the heater core box is in order.
    There is also a post somewhere with a link to making your own manometer using stuff you can get at a hardware store. While I do agree that a dyno would be in order to fine tune the carbs, the manometer is just used to balance them for a starting point.
    And Ummm... Baz... if you have a set of intakes sitting around being used as a doorstop, you could always send them to me.....I'd gladly support your next fishing trip!
    joe
  22. #20
    Dec 2009
    Vienna, VA
    860
    Jim
    http://obairlann.net/reaper/motorcycle/manometer.html
    We use them on BMW bikes all the time!
    Personally I like the Twinmax. It is less messy and easier to use:
    http://www.aerostich.com/twinmax-synchronizer.html
    As said though, for this it is just a solid starting point, but you can get them close enough to drive with.
    Jim
    1. Replies: 1
      Last Post: 12-09-2009, 10:27 PM
    2. Manifold vacuum on 1.1L dual carb
      By 73Manta72gt in forum 6E - Tune Up
      Last Post: 12-02-2008, 08:57 PM
    3. 1.9l dual carb intake
      By okiejohn in forum Aftermarket Side-draft carbs
      Last Post: 01-14-2006, 05:26 PM
    4. air horns for sidedraft carb
      By Crusher in forum Aftermarket Side-draft carbs
      Last Post: 03-09-2005, 08:35 AM
    5. dual carb intake manifolds
      By Lasse H in forum Aftermarket Side-draft carbs
      Last Post: 03-13-2003, 07:38 AM
