Unanswered: Dellorto DHLA40 N jetting
I have a pair of Dellorto's DHLA 40's N and want to use them on a 2.0 engine with a free flow exhaust and a 11.1 C.R. The carbs are jetted as follows Main jet: 130 Emulsion tubes: 7772.10 Air : 180 Can i use the carbs with this jets or i have to rejet them. If so, what other jets would you recomend me. |
#2 (permalink) | |
34mm chokes 35 accelerator pump jets 140 main jets (richer) 180 air correctors (no change) 7772.10 emulsion tubes (no change) 55 idle jets standard idle jet holder 7848.3 auxiliary venturi 1.50 needle and seats 15mm float shutoff height 25mm full drop float setting idle adjustment screws - 4 turns out from lightly seated Contact Gabrielle's site (Italy) for parts.
tekenaar jets for the weber 32-36
betacarotene, do a search for "tekenaar jets" its listed several times here on this site, i cant remember from memory
Remember too that your modifications affect the jetting. High compression or low compression engine? Stock cam? Stock exhaust? Ported intake? Your altitude is critical too, higher elevations require less fuel to compensate for lower air density.
Bob |
