Any suggestions.. BTW: These carbs will go into a fairly warmed over 1.9 w/ 2 - 40 DCOEs, between 9.5-10 comp, larger valves & solid lifters w/ a ballpark figure of between 125-150 hp. TIA Hiergehts |
Hier gehts:
130 mains 190 airs F11 emulsion tubes 35 pump jets 34mm chokes 4.5 aux. venturis 40 F9 idles 7.5mm float level shut off height 15mm full drop float setting These should be VERY close to what your engine needs. Good "cold air" system to feed your twins wouldn't hurt either.
1960: ♥ '61 Rekord PII 1.7 3S 3.9 ♥ '69 Kadett LS 'sprint' 1.9 3A 3.18 1970: ♥ '70 GT 1.9 4S 3.44 ♥ '72 GT 2.2SSD 5S 3.44 ♥ '72 GT 2.4FI 5S 3.44P 1980: ♥ '85 Bitter SC 3.9FI 5S 3.44P 2000: ♥ '09 Solstice GXP Coupe 2.0 SIDI VVT Turbo 5S 3.73P Last edited by tekenaar; 09-11-2004 at 11:16 AM. |
No Access
Try this link to a very good article on some of the basic jets tubes and chokes for side drafts. It was the best info I have found and easy to follow.
http://www.opelgt.com/forums/showthr...highlight=DCOM |
No Access
When I give you the numbers that are in it right now you'll understand why I looked all over for some of the info that I did. I'll start by telling you that a stock OM has a different accelerator pump that is manual so no jetting of it is required. Right now I have 138 mains with an F64 emusion tube and idle jets are 59F21. Ok if that isn't odd enough my air carrier is a 160 not a jet but the carrier is 160. I run 32 chokes but may go to 30s to compensate for the lost torque with the upcoming cam. I'll probably drill out the carrier and do something like a 180 or 200 for an air. On the flat top 1.9 it was too rich this way but on the 2.0 it is just about perfect with great transition. I'm thinking only about the airs and maybe just maybe trying the 30s. I did find some short horns too but figured if I'm ordering from Italy I might as well do it all at once.
I would like some advice about a dual 40 DCOE also. I am building a 1.9/2.4 conversion, roller rockers, large chevy valves and would like to hear what jetting is likely for this engine. Thanks in advance.
TMK |
