Opel Community Forums
Go Back   Opel Community Forums > Opel Forums > Classic Opels > Ascona (1900)
Ascona (1900) Please post technical questions in the appropriate Technical Forum, unless it is very specific to the Ascona.
  #1 (permalink)
Old 05-06-2008
officertyo's Avatar
wicked wagoneer
Rating: 0% (0)
officertyo is on a distinguished road
Fan belt shredding
Ok, i have finally got my 71 1900 wagon on the road and have been driving it for the past 2 months or so. I seem to have a problem with the belt that is just down right driving me nuts. The edge of the belt keeps shredding away and making the belt loose. I am on my third belt now, this one being one of those heavy duty agricultural belts and its doing the same thing. I have cleaned all the grooves in all the pulleys of rust and all pulleys seem to be in line. Has anybody else on here dealt with this and what did you do to fix it?
Just to clarify the belt is not being streched its being worn away on the sides of the "V" the ride in the grooves of the pulleys.
Thanks Ron
  #2 (permalink)
Old 05-06-2008
Sparky73's Avatar
Rating: 0% (0)
Sparky73
I had the same problem in my GT. For some reason the alternor was out of alignment. I solved the problem by adding washers, or spacers, to the alternator.
Current
1970 GT; Red with Red Interior (Restoration Project)
1969 GT; Street/Strip Project (For Sale-Best Offer?)
Previous
1969 GT; Black Parts Car
1969 GT; White Parts Car
1972 GT; Red Parts Car
  #3 (permalink)
Old 05-06-2008
tomking's Avatar
Rating: 0% (0)
MOST LIKELY THE PULLEY ON THE CRANK AND THE PULLEY ON THE ALTERNATOR ARE NOT IN LINE. If you stand by the side of the car and sight inline with the belt you should be able to detect the misalignment. Probably the alternator needs to be shimmed towards the front or back. It is possible, but not as likely that the crank pulley is loose. Check the large 19mm? bolt that holds in on the crank to make sure it is tight. If so then you must move the alternator. I have had the same problem and may be caused by worn rubber bushings that hold the alternator.
TMK
  #4 (permalink)
Old 05-06-2008
officertyo's Avatar
wicked wagoneer
Rating: 0% (0)
I was thinking the same thing on the rubber bushings. Maybe they are just worn out. Is there any way to just get rid of them and mount the alt solid?
  #5 (permalink)
Old 05-07-2008
4246 Post Club
Rating: 0% (0)
Solid ...
Originally Posted by officertyo View Post
I was thinking the same thing on the rubber bushings. ... Is there any way to just get rid of them and mount the alt solid?
Some people replace them with ali bushes - but it is probably better to use Nolathane suspension bush material to keep a bit of flexibility and vibration isolation in the mounting system. Use one of the harder grades (black?)
Copyright © 2000-2008
Powered by vBulletin® Version 3.7.2
