Go Back   The Classic Opel Forums > Opel Forums > Classic Opels > Ascona (1900)
Ascona (1900) Please post technical questions in the appropriate Technical Forum, unless it is very specific to the Ascona.
Old 01-11-2009   #1 (permalink)
74Opel1900's Avatar
Real Name: Brian
74Opel1900 is on a distinguished road
Answered: Speaker size and other questions
My 1974 2 door Ascona never had a radio and the dash is uncut. I have a couple of questions. What size are the stock speakers and where are they located. I don't plan on cutting the dash. I just want to put two speakers in the back deck, an amplifier in the trunk and run a cable to the console for an mp3 player. I've never installed a stereo before so any additional information would be welcomed.
74Opel1900 is offline
Most Helpful Answer - Posted by BQS4
Originally Posted by 74Opel1900 View Post
The holes measure 4 inches so only 4 inch speakers can fit in the deck without cutting to make the holes larger. It's going to be hard to get halfway decent sound with only two 4 inch speakers in the rear deck. Looks like I'm going to have to explore options for kick panels or door panels. You were right, there are a series of small holes above where the radio mounts. Does the dash have to be removed to install a speaker there?
What you can do, if you don't want to cut the back deck, it just build some simple "surface mount" enclosures, out of wood, then you can put 6X9's back there. As for the dash speaker, no the dash does not have to be removed. Just remove the glove box and it's right there to the left.
Old 01-11-2009   #2 (permalink)
manta73wi's Avatar
manta73wi
I like the idea of leaving your dash uncut and using an mp3 player. I use a set of battery powered computer speakers with my iPod when I don't want to go with the stock AM in my '73 Manta. As far as I know, the only stock speaker in the US Manta/Ascona models would be a single speaker which would be located right above where the radio would be, facing down towards the floor. I believe this would be a dealer installed option. It is an oval shaped speaker, and there are a series of small holes in the dash to let the sound out. I'm guessing the dashes all came with the holes, but all of my Mantas have had the dealer installed radio at one time. I don't know what the size of that speaker would be. Some folks do put speakers in the rear deck and in the door panels. My '75's PO put them there, so I cannot help much with what he did.
-Jeff W.
manta73wi is offline
Old 01-11-2009   #3 (permalink)
74Opel1900's Avatar
Real Name: Brian
There are no holes in my dash for a speaker. Does anyone have a picture of speakers installed in the rear deck? Also, if anyone installed speakers in the rear deck, what size did you use? Any suggestions on where to run cabling would also be welcomed.
Old 01-11-2009   #4 (permalink)
The front speaker mounted behind the dash, on that flat area just above where the radio goes. You can see perforations if you look under there, or run your hand along the flat surface. As for the rear deck, pop the trunk and look up at the shelf and you'll see factory cut outs.
Old 01-11-2009   #5 (permalink)
74Opel1900's Avatar
Real Name: Brian
I had a feeling you would reply BQS4. From inside the trunk I've seen those factory cut outs in the rear deck. My car is in the shop so I can't measure the holes. Guess I'll have to wait until I measure them to order speakers. I'll also need to make a new rear deck since mine is falling apart.
Old 02-09-2009   #6 (permalink)
74Opel1900's Avatar
Real Name: Brian
Old 02-09-2009   #7 (permalink)
Old 02-09-2009   #8 (permalink)
74Opel1900's Avatar
Real Name: Brian
What size speaker fits in that area of the dash?
Old 02-09-2009   #9 (permalink)
long time Opeler
deaner's Avatar
Resist any speaker that is oval in shape.
I put 6.5 JL Audio speakers in the door panels and also in the rear deck. I cut the sheet metal in the doors and the rear shelf.
If you want bass you'll need to install a sub. There is plenty of room to install a killer system.
Just remember, you can use cheap speakers on a high end radio and get terrible sound, you can use high end speakers on a cheap radio and get good sound.
deaner is offline
Old 02-09-2009   #10 (permalink)
74Opel1900's Avatar
Real Name: Brian
Got any pictures of your install? That goes for anyone that has an aftermarket audio system in their Ascona. Let's see some pictures.
Old 02-09-2009   #11 (permalink)
It's a real weird size, but, with a little engineering you might be able to slip a couple of tweeters in there, or maybe one dual cone.
Old 02-09-2009   #12 (permalink)
You can also go this route, from J C Whitney:
Audiosonic DELUXE OVERHEAD SPEAKER SYSTEM - 200-WATTS : JC Whitney: Auto Parts & Accessories
I have this system in my Sportwagon and there should be no reason it wouldn't work in your Sedan. Here's a thread about it, and a pic of the system in my Sportwagon in post #15
http://www.opelgt.com/forums/sound-s...locations.html
Old 02-09-2009   #13 (permalink)
74Opel1900's Avatar
Real Name: Brian
Those are interesting, good to know there are other options.
Old 02-10-2009   #14 (permalink)
I've done angled spacers for the rear deck (better acoustics than flat mounting) with 6 x 9 speakers. And I've made custom front kick panels with angled spacers and 5.25" round speakers. Amps I've either mounted on the rear axle hump, or conversely I've hung them from the underside of the rear speaker deck with spacers (for air flow).
I typically have avoided cutting holes in the door panels. They're not getting any easier to find!
Old 02-10-2009   #15 (permalink)
74Opel1900's Avatar
Real Name: Brian
Got any pictures of your setup Bob?
Old 02-10-2009   #16 (permalink)
74Opel1900's Avatar
Real Name: Brian
I was told by a local car audio installer that there is a bracket where by two 3 inch speakers can be installed into the dash where there is usually a single stock speaker. I'm going to look into this option.
Old 02-10-2009   #17 (permalink)
Nope, nothing digital. I could take some pics of the rear deck (I have one car at my shop now) and look for some 35 mm pics I have of the forward kick panels.
Old 02-11-2009   #18 (permalink)
74Opel1900's Avatar
Real Name: Brian
No need, just curious what your setup looks like. I think I got it all figured out, thanks.
Old 02-23-2009   #19 (permalink)
Downloaded some pics of the Ascona speaker mounting options.
Old 02-24-2009   #20 (permalink)
As usual Bob, excellent craftsmanship. Question though, you've mounted the speakers so that they look level to me. Isn't the back glass used to bounce the sound forward? It's my understanding that bass is non directional while the midrange and treble are directional and either need to be aimed toward the listeners or as an alternative can be bounced off hard surfaces.
hrcollinsjr is online now
Old 02-24-2009   #21 (permalink)
74Opel1900's Avatar
Real Name: Brian
Nice installation. I will consider doing this when the time comes.
Old 02-24-2009   #22 (permalink)
Harold, I wont pretend to know much about stereos, it's not my thing! All I know is, when the speakers were mounted totally flat on the rear deck, it was tough to hear them at highway speeds over the tire noise, wind noise, and exhaust noise. Angling them upwards a bit made it easier to hear at a lower volume level.
Old 02-24-2009   #23 (permalink)
Sounds to me (no pun intended) like you made an improvement then. As long as you're going forward I reckon that's all that counts.
