Unanswered: 205/60R13 Tire Size for Ascona?
#2 (permalink) | |
HTH, Harold |
UFO pel abductee.
Just put 205-60/13's on my '75 Manta with stock 5.5x13 wheels and they clear everythging just fine. Lock to lock on the steering. My car hasn't
been lowered though. Pics iare n my 'aardvaark' album of them on the car.
UFO pel abductee.
Here are a couple of pics of inside full lock without the front engine
lower shield being trimmed on my '75 manta with the stock rims and 205-60/13 Sumitomo HRT200's. They should clear on the Ascona, not sure tho. Also no issues in the rear. I can rum my fingers along the fender lips without contacting the tires. So I'd say at least 3/4" clearance in the rear.
-Mark '75 Manta Direct link to my album of Opel related parts catalogs and magazine articles for reference: http://www.opelgt.com/photopost/show...ser/23031/sl/a Last edited by Aardvaark; 02-22-2009 at 08:31 PM. |
Thanks for the info. Maybe the half inch off set was enough to clear the rear. Looks like I would still worry about the front on your Manta. Looks about the same as I remember on mine. At one point in time it did manage to grab the lower shield and bent the sheet metal pretty good. I remember being quite upset about the deal. Seems I was reversing at full lock and the wheel cycled enough to grab the lower shield and bent the fender a good 6 inches up from the shield/fender attachment location.
![]() How do you like those tires. I was looking at them myself, but we do get some snow in our area so I think they are out. I am looking at the General Altimax RT's or the Kumho Solus KR21's in the 185/70R13. I think if I do go with the 205/60R13's I will probably go back to the Cooper Cobras I use to run. Thanks George. |
UFO pel abductee.
Bill |
#8 (permalink) | |
I have run 205/60's on most my Mantas and Asconas, an like most have said, when you back up in a turn, it'll catch the front edge of the wheel well lip and the splash pan. But a little trimming clears this all up andyou can't see where the triming was done, unless you lay down in front of the car
"Yes, I do have a rifle rack in my Sportwagon" Last edited by kwilford; 02-23-2009 at 11:36 PM. |
The 185/60/13 is a 21.7" diameter tire according to the miata.net calculator. The 205/60 is a 22.7" tire which I believe is the stock diameter. It seems like some people go with the 23" diameter as well.
Theo
SIGNATURE |
UFO pel abductee.
FYI:
Its easy to calculate any tire dia. In the case of 185-60x13: (185mm) times (.6 aspect ratio )times (2 sidewalls) divided by (25.4 for mm to inches) plus (13 for rim dia.) = tire dia. 185 x .6 = 111 111 + 111 = 222 222/25.4 = 8.74 8.74 + 13 = 21.74"
I did a search, but could not find any info for my question. Thought I would post here so as not to clutter up things. I was given a set of aftermarket rims that came off of a Opel GT and I know that the offset is different. I was wondering if you stay near the original sized (165/80R13) if there would be a issue or not. I was thinking of going with a 175/70R13 which I believe would be a slightly smaller diameter than stock. Anyone try this? Thanks, George.
Well I measured the back space and found that the rims that were given to me are exactly 1 inch shallower. I see that some are using a 1" spacer on this thread so I figure I should be ok.
http://www.opelgt.com/forums/3d-whee...l-spacers.html George. |
