Opel Forums
Go Back   Opel Forums > Opel Clubs > Canadian Opel Club
Canadian Opel Club Opelers in the Great White North now have a forum to discus meetings in Canada.
Old 12-28-2007   #1 (permalink)
Old Car Guy !!
1.9 GT's Avatar
1.9 GT is on a distinguished road
Question Opel Battery
I see the Opel manual for the 1973 GT lists a Delco General 12 volt 44 amp hour original equipment. The replacement battery listed is a Delco Energizer Y55. According to to my local supplier this number no longer exists. Does anyone know the required cranking amps for a safe replacement battery "500?"
1.9 GT is offline   Reply With Quote Top home
Old 12-28-2007   #2 (permalink)
4246 Post Club
Cca350
Anything between 350 and 500 Cold Cranking Amps will do the job - the colder (ie: further North) its, the higher the numbers!
Many people use a 'gel' battery to minimise the acid damage to the battery holder/belly pan.
Just get a good Heavy Duty battery that fits the battery holder!
Copyright © 2000-2008
Old 12-28-2007   #3 (permalink)
opelwasp's Avatar
opelwasp
I just use a 1000 CCA Orbital from Exide.
opelwasp is offline   Reply With Quote Top home
Some People Are Like Slinkies. They're Not Really Good For Anything, But They Bring a Smile To Your Face When Pushed Down The Stairs."
Remember: Advice and Opinions are free, take it for what it's worth.
Caution: Driver carries less then $20 of remorse.
Old 12-28-2007   #4 (permalink)
Old Car Guy !!
1.9 GT's Avatar
Thanks
Thanks for the advice will measure new replacement tray and go for gel
Old 12-28-2007   #5 (permalink)
I think a better idea would be to measure the distance between the radiator support and body, between the hood hinge supports, to see how wide it is, then get a battery that will slide down between the two.
Old 12-29-2007   #6 (permalink)
opelwasp's Avatar
opelwasp
My gel cell fit between just fine.
Old 12-29-2007   #7 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
Were I going to put a battery in a GT ever again, it would be one of these, made for a Miata:
http://store.miataparts.org/wessealbat.html
They're a fully sealed battery, 350 or so CCA, and absolutely tiny. Easy drop in, no more rust, only 25 pounds, what's not to love? They're also AGM batteries, which have been lasting up to 10 years under normal use in Miatas.
oldopelguy is offline   Reply With Quote Top home
