Old 06-30-2006   #1 (permalink)
neuropel's Avatar
Unanswered: Are all Getrag 265 5 speed transmissions the same?
Can anyone tell me if a Getrag 265 from another make (i.e. BMW) will work as a straight bolt-on with the Opel 6 cylinder CIH Getrag 265 bellhousing? In other words, are all 265s created the same? The reason I ask is that I believe the 265 transmissions can be found in the US, and it'd be MUCH cheaper to ship a bellhousing from Europe to the US than a combo 265 tranny/bellhousing.
Anyone know of an available 265 tranny in the states?
Todd
-Abraham Lincoln
________________
1972 GT 2.4L
1974 Manta GT/E 2.2L
1973 Manta Rallye 2.5L
neuropel is offline
Old 06-30-2006   #2 (permalink)
My understanding is the 265's installed in BMW's use a different speedo drive (no big deal really) and a different driveshaft type (rubber guibo joint). So making a driveshaft might be an issue, since there's no u-joint at the front of the driveshaft.
Old 04-09-2007   #3 (permalink)
neuropel's Avatar
<bump>
Are the issues Bob mentions here show stoppers? Curious if anyone has tried an Opel bellhousing onto a BMW transmission?
Todd
PS - I had to look up what a guibo joint was. Learn something new EVERY day!
-Abraham Lincoln
________________
1972 GT 2.4L
neuropel is offline
Old 04-10-2007   #4 (permalink)
No Access
The shifter for a 265 is quite a bit further back and it has a single casting front end like a 240. Break out the mig and the tig and all sorts of saws. If I'm wrong about that please let me know about a BMW not having the starter on the other side. As for the rear driveshaft output if you have a disk made to adapt the drive shaft to the bigger of the BMW bolt circle mounting plates. You can use a stock driveshaft after it's trimmed down and welded and rebalanced.
GTJim found a shifter adapted for a GT with pics and a few dimensions on German Ebay. It hits on center 1/2 inch further back
Oh and the 265 would sit about 2 inches taller in the front of a GT at the firewall area. About the same height or just under what a stock motor mount measures. The driveshaft length for a GT is a cut just before the front U joint for a GT if the mounting flange you have made is 3/8 inch thick. This is for a GT so adjust as needed for other models.
nobody is offline
Old 04-10-2007   #5 (permalink)
jordan's Avatar
I look up more words that bob posts than anyone else, this guibo joint is new to me as well.....and nurburgring......and Zugstrebe.
1970 Opel GT 1.9
1980 Moto Guzzi V50
2000 Saab 9-3 2.0 turbo
2000 KTM 200 exc STOLEN
jordan is offline
Old 04-10-2007   #6 (permalink)
No Access
The guibo for a 265 is about 2 inches thick and uses 2 sets of 3 bolts to bolt in either direction and would be an all new idea that would take both the BMW driveshaft and a GT one. It also requires the driveshaft carrier from a BMW since it has no front U joint then. Might take a bit more tunnel changes to make that fit up. The 265 guibo is a rubber dampening ring with steel collars for all the bolts so it'a a hard mount basicly and then you get to align both the tranny and motor to the carrier and then the rear diff.
BTW the guibo, shaft and carrier runs about 325 bucks and the design work is about 100 hours if you do it yourself. A shifter alone is 125 if you slip up on it too. I forgot to mention there is one 265 crated up for a GT and another out for a bit of work plus a pair of 240s here. I don't have a 4 speed anymore, worth saving at least.
nobody is offline
Old 04-10-2007   #7 (permalink)
No Access
Oh, I amost forgot the clutch issues with the 265 for an Opel. The clutch stud and carrier for the the throw out bearing...they are both too short to use unless you find a 2.4 clutch and flywheel. The 265 has a fixed clutch stud so you would need to fix that as well as the carrier length being about an inch short....that 2.4 clutch package alone is 72 pounds, and the 2.4 tranny is around 80 pounds vs the 46 for a 4 speed. So build for the added weight.
nobody is offline
Old 04-10-2007   #8 (permalink)
Originally Posted by nobody View Post
..and then you get to align both the tranny and motor to the carrier and then the rear diff.
IRS also needed???
Old 04-10-2007   #9 (permalink)
No Access
Yes Harold, I looked into the rear diff question and almost any missalignment will tear up the driveline. Same as your rear diff shifting angle with a standard rear like all the US Opel models I've seen do unless the alignment I mentioned is done very well. OK some good news. If you do the adapter plate you don't have to double your cost and you have only a single cut and rebalance of the drive shaft and it's almost as long as stock so balancing is pretty easy to get done. The 265 actually uses a longer drive line than a 240, go figure.
nobody is offline
Old 04-17-2007   #10 (permalink)
No Access
While I'm thinking about it I might as well give the dimensions for a 265 adapter plate.
5 inch round, turned flat and parralel to 9.7mm thick.
16mm through hole on center for the stud on the output.
3, 11.85mm holes at 120 degree intervals at 48mm centers from the center of the plate.
nobody is offline
