Opel Forums
Go Back   Opel Forums > Performance and Racing > Performance > Clutch, Transmission and Drive-train Upgrades
Old 07-27-2007   #51 (permalink)
neuropel's Avatar
Todd, for some of your questions refer to the article I mentioned earleier, the answers are all there.
Ron,
I'm trying to figure out which article you mean? You mentioned a T5 article on the main google page, but what were your search criteria? Just "T5" brings up a lot of things. Using "T5 transmission" brings up the following:
Identifying and Assembling a T5 5 Speed
Is this the article you mean?
Thanks!
Todd
neuropel is offline   Reply With Quote Top home
"I'd rather have a bottle in front of me than a frontal lobotomy"...
________________
1969 Lenk GT
1974 Manta
1973 Manta Rallye
Old 07-27-2007   #52 (permalink)
This would be a great topic to bring up in the chat room. If all the interested parties could agree on a time and date
Old 07-27-2007   #53 (permalink)
Originally Posted by neuropel View Post
Ron,
Thanks!
Todd
Let's see if this works, here's the link for the gear ratios: The T5 page and at the bottom of the page there is a link to a Camaro T-5 Hybrid that shows the "how to" on changing out the tailshaft.
Old 07-27-2007   #54 (permalink)
So Famous I'm Infamous
Phoenix's Avatar
Classified Rating: 100% (1)
Keith Ludholm did a Chevette 5 speed for Dallas' spyder. The shifter is placed about 3 inches or so back from the orginal location.
Car-part.com has a bunch of Chevette 5 speeds from the gas engine, from what I can tell 82-87. Keith said Gas engine, not Diesel.
While not the best for a street application, you start talking about high HP, and close to 2 grand, what about the ZF transmission? Can that handle the numbers you guys are talking about? And I know that they're rare, I'm just saying...
Phoenix is offline   Reply With Quote Top home
6-speed transmission??? That's 2 more gears than I need!
Old 07-27-2007   #55 (permalink)
neuropel's Avatar
Well, in any case, it looks like the ONLY tranny I could use with the chevette bellhousing is the chevette T5 since the bolt pattern is different. It appears that the tail shaft housings are interchangeable, so a S10 tail on the chevette T5 might make for a nice 5 speed for a stock motor. No idea what the cost might be to get a chevette T5 beefed up for higher HP applications, or whether it's even possible. But I'm going to check.
Perhaps a better option might be stephen's adapter with a camaro T5 and S10 tail housing. This would give a close ratio 5 speed and put the shifter right. The torque rating for the NWC T5s appears to be on the order of 265 ft/lbs - that's LOT for an Opel CIH motor.
Todd
________________
1969 Lenk GT
1974 Manta
1973 Manta Rallye
Old 07-27-2007   #56 (permalink)
Paul
Good Stuff
Originally Posted by RallyBob View Post
However the tranny is still only rated for 230 ft lbs with the S10 guts.
It would appear that 230 lb-ft of torque would handle most of the mild and moderate modifications to the CIH 1.9 and 2.0's, maybe even the 2.2, and some of the mild engine swaps...
Mustang T5 good for 330 ft lbs of torque.
This would cover most of the wild CIHs, turbos, and higher HP engine swaps
Obviously, there are many differing tranny options and engine modification levels. However, is it possible to drawn the line at a point where 2 or 3discrete tranny options could cover 95% of everyones needs. Or is that too optimistic....?
If there appears to be a natural brake between the two solutions, then it looks like it would be beneficial to define the separation point and help direct information to to complete both paths.
You guys are doing a great job of fleshing this stuff out. I know there are many sitting on the side lines very interested in the outcome, but don't have the knowledge to contribute or sort this stuff out for ourselves. Well, I know I don't...
Keep up the good work!
Paul is offline   Reply With Quote Top home
Paul
Old 07-27-2007   #57 (permalink)
I fully agree. This would cover 98% of us here in the US. There just aren't too many making that kind of torque unless we're talking about an engine swap.
Old 07-27-2007   #58 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
hp limitations
So, to me it looks like the Camaro v-6 T-5 with the S-10 tail housing is about the closest ratio we're going to easily get with the input shaft and bolt pattern I have in mind for this adapter. This hybrid transmission would be good for probably 175 hp and 200 ft-lb of torque without much issue, and would have a shifter coming out very near the stock Opel hole. It would also use whatever Opel clutch option already on the car. Expect such a transmission to cost in the $4-600 range.
We're pretty much all in agreement on these facts and figures?
Since these hp and torque #'s correspond pretty close to the limitations of the rest of the stock Opel drivetrain, this creates a natural break in applications, I would think: This transmission configuration would be suited to stock or mild engine upgrades where the stock rear end is retained. If your application needs more axle than stock, then it probably needs more transmission than this as well.
Agreed?
If your horsepower aspirations are such that you were already planning on needing an axle upgrade, for round #'s let's just say 200hp or so, then we need to persue other options. Also, if you need tighter gearing for racing applications, you would want something else.
Agreed?
As to other ideas using the T-5, do we agree that we have the following?:
-Looks like the S-10 tail housing can be adapted to even the Mustang transmissions, so for applications looking to use the stock shifter location we can pretty blanketly say to use the s-10 tail on whatever T-5 you use. For a closer location you would want to use a different tail housing.
-Looks like the Chevette t-5 has closest ratios, but it's a rare bird and not very high hp rated. This would be the best solution for racey performance on a nearly stock motor and stock drivetrain, assuming you could ever find one.
Issues still outstanding?:
-Since the Chevette bell housing uses the Ford bolt pattern, it may be possible to bolt the Ford transmission to the Chevette bell housing directly. This would yield both good ratios and high hp capacity, and is worth seriously looking into. We know where one such bell housing is right now, would it be possible to get Lakewood or the like to make up a copy in a scattershield?
-The adapter for the v-6/4-cyl S-10/Camaro trans to the Opel bell I'm trying to get built would also allow bolting in other 70's GM transmissions, including t-10s and Corvette 4+3's. These transmissions have excellent ratios availability and strength, but do not have overdrive. Would these be worth considering for race-only applications?
-Other discussion items?
oldopelguy is offline   Reply With Quote Top home
Old 07-27-2007   #59 (permalink)
No....its not a Buick....
yellaopelgt's Avatar
So the question at hand then might be......Is this tranny combo realistically easier to obtain/cost/piece together than the Getrag?? And...in my application.. would the shifter location work in a GT??? I think the biggest reason I dont just go ahead with my Omega 2.4 tranny transplant is the fact that I refuse to cut up the tunnel.And to move the motor mounts forward 3" to acommodate it doesnt thrill me either. A bullet-proof tranny at low cost has been on most of our minds for years. Its just to actually see one in a car that makes this hard to believe. I'm sure its do-able, (for the mechanical guru's) but for a guy like myself with limited skills, what we are looking for is a "dummies" version.Bolt and go would be a slice of heaven.
Joe
yellaopelgt is offline   Reply With Quote Top home
What we got here is........failure......................... to communicate....
Old 07-27-2007   #60 (permalink)
Do you have any detailed close-up pics of the shifter itself? From multiple angles? Maybe it can be modified to fit, you never know!
Old 07-27-2007   #61 (permalink)
I'll get some pics up tonight for you.....and I'll put them in the crate motor part deux thread so I dont clutter this one up!!
Joe
Old 07-27-2007   #62 (permalink)
opelnut10's Avatar
T-5 Shifter
There are several after-market shifters available for the T-5, Mustang, Camero S-10 truck and on and on. I was looking at a Mustang shifter to make the S-10 T-5 placement come out in the right place in a GT and not have to modify the hole location. Google up T-5 shifters and you will see lots of shifter options, some being short throw (less movement of shifter handle) and they all fit the T-5
opelnut10 is offline   Reply With Quote Top home
Old 07-27-2007   #63 (permalink)
Folks, I just thought of something I had to do on Willit? You remember, my main concern on my engine swap was to center the shifter in the console hole. My first attempt failed due to my lack of concentration. I used the front set of holes (manual tranny) to build my first subframes, that put the shifter up against the front of the hole. Then I modified the subframes, moving the mounting holes back 2.5" to pick up the rear (auto tranny) holes. This required adding a 4" X 6" X 1/2" plate to the rear of my original tranny subframe to pick up the tranny mounting pad and notching it on the front to clear the diagonal casting web on the bottom of the tailshaft housing. All this is covered in detail, including pics in Phase II of my Engine Swap articles. One thing I must reiterate, if you do center the shifter in the console hole with an S-10 tailshaft housing, there will be less than 2" between the U-joints on the driveshaft, if you use the S-10 front yoke with an S-10 U-joint and the Opel rear U-joint. I'm hoping Stephen has figured out where the shifter will be using his adapter with the Opel bellhousing. If it's within, say, 1"-1.5" forward of center in the console, there shouldn't be any problem, if it's further back than centered, there won't be enuff room to put in any driveshaft.
Old 07-27-2007   #64 (permalink)
Certified Opelholic
davegt27's Avatar
I know most people have seen these but just in case someone missed them
http://www.opelgt.com/photos/data/50...warner_T-5.jpg
http://www.opelgt.com/photos/data/50...vy_S15_T-5.jpg
http://www.opelgt.com/photos/data/50...07S-15_T-5.jpg
Davegt27
davegt27 is offline   Reply With Quote Top home
Old 07-27-2007   #65 (permalink)
neuropel's Avatar
How about the input shaft side of the mustang T5 though? I think it's 1 and 1/16 and 10 spline versus the S10 1" and 14 spline. Changing the input shafts changes the gearing too, I'm fairly sure. If it's do-able, we're gold, but I have my doubts on how easy it is.
I will DEFINITELY donate my bellhousing to whomever wants to try to make copies, templates, or whatever. Just let me know.
Todd
________________
1969 Lenk GT
1974 Manta
1973 Manta Rallye
Old 07-27-2007   #66 (permalink)
oldopelguy's Avatar
Logbook Entries: 3
How about the input shaft side of the mustang T5 though? I think it's 1 and 1/16 and 10 spline versus the S10 1" and 14 spline. Todd
I think it would be easier to find a clutch disk to work with the Mustang input shaft, but I have done no research on that at all.
Old 07-27-2007   #67 (permalink)
It should be relatively simple. I did this when I fitted a Getrag 265 tranny with an S-10 clutch, I had a custom disc made to fit the 265 spline, only cost about $140.
So using an S-10 pressure plate with a custom disc to fit the T-5 should be no issue either.
Old 07-27-2007   #68 (permalink)
Todd
That may work if the pilot bearing end of the input shaft is the same. If not it may have to be either machined down or built-up then machined down. Another cost factor added.
Old 07-27-2007   #69 (permalink)
neuropel's Avatar
